Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
My machine is continually filling up with soapy water even with no washing powder and then goes of with power button and mini load buttons flashing
  • louheathcote Jun 01, 2010
    Thank you, how do I do this???
    Many thanks
    Genius:
  • Hotpoint Master
  • 1,474 Answers
This sounds like the drain hose is 1st too low next allowing sink waste to enter the machine , you should check this.
Posted on Jun 01, 2010
  • Gerry Harvey
    Gerry Harvey Jun 01, 2010
    Lift the hose to a minimum height of @least 2ft from floor level, this should help solve wastewater from sink entering the machie via the pump...
My Samsung washing machine wont stop with water filling
First clean the detergent drawer and button trap, then make sure the siphon cap {it might say "MAX" on it) is installed properly. Make sure water pressure is not too high.
Apr 18, 2016 | Samsung Washing Machines
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Soap residue
if you just have a soapy residue( bubles atop the clthing?? either your using way to much soap, or way to much of wrong soap.you need to use HE detergent specifically formulated for front loading amchins(low sudsing. or your having a cold water inlet problem set te hunit to cold/cold/ try running see if inded the machine fills
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wahing machine kitchenaid won't completely drain water
Check drain pump for any blockage.Pump accessible by removing lower panel,on bottom front of machine.Also try liquid instead of wash powder,and make sure that you are using automatic powder as other will foam in machine.
Apr 01, 2008 | Indesit W 123 Front Load Washer
My washing machine doesnt stop filling the tub when the right water level is reached, it will just continue filling and never stops filling. Can anyone suggest what is wrong and how to fix this?
Not familiar with this model. When a washing machine fills with water up to a predetermined level, it usually operates a pressure switch which will turn off the water valve, and redirect the power to the programmer, or heater, or some other stage of the programme. If there is a blockage of powder or gunge in the tube leading to the pressure switch this would prevent air from rising up the tube to operate the switch. Tom.
Feb 27, 2007 | Admiral AW22 Top Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
51 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
