Question about Coffee Makers & Espresso Machines
Iron stopped steaming
I was useing my steam iron when all of a sudden it stopped, nothing i did would make it work againg, it now will only work as a standered iron which isn't good enough, it has worked great and i have been very satisfyed with it untill now.
Pleease can you get back to me asap on who i need to send my iron to to get it fixed and i need it sorted very quickly.
Many thanks
miss hilton
    Genius:
  • 1,416 Answers
the problem of your iron is from the wire connected to the element (heat provider ) of your iron bass on the information pass across to me
what you need to do bring back your iron to life is to trace the wire down to the element at the back of it were the power supply pass through .
Before you can carry out this function you will have to put off all form of power supply.
thank you and thanks for using fixya.
Posted on Jun 01, 2010
Why has the steam function has just stopped working - power on but nothing happens
My wife has one of these irons and she loved it. Now it steams for a while, and a red light starts blinking and it stops steaming. It can be turned back on and works for a while, then the same thing happens. I read that it needed descaled, so I bought OUST descaler and ran it through the iron, but it did not solve the problem. Any one have a solution to this problem, I would like to hear from you.
Jul 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
I have a Bosch Steam Generator Sensixx B25L that has suddenly stopped producing steam. The iron gets hot so that bit is ok, help, I have a huge pile of ironing!
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Jun 01, 2011 | Irons
We have a trusted Philips Azur Precise 4310 iron. Worked fine for the 2-3 years we have had it - then, suddenly, nothing! Power light on handle has gone out and the iron has completely stopped working...
It looks like a problem with the power cord. Try splicing the cord with a new one near the base of the iron and see if this helps. If not, it could indicate some connection problem inside the iron. In this case, it would be cheaper (and wiser) to simply go in for a new iron box..
Sep 28, 2008 | Philips Computers & Internet
How to use steam iron
Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
Feb 23, 2008 | Micro Pro 7599 Iron
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
