Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Camera freeze when i took some photographs my 400d just crashed completely froze can anyone help please
  • Anonymous Jun 20, 2008
    Camera about a year old firmware 1.0.4 can sometimes take several photos then the camera freezes with the CF light on as if trying to write to card, have tried alternative card (both lexar 2g) same result the only thing to get going again is remove the battery. any help please.
    thanks
Check your battery level
If the bettery level appear 2/3 >> you should recharge before using it next time
There's no problem,just keep your battery at full health
Posted on Jul 04, 2008
My memory card has been virus affected. The photograph I took are shown on camera display but when I connect the camera with my PC it does not show any DCIM folder inside camera memory card. Can anyone...
You need to try downloading the pics using a separate card reader. If this is successful and your pics end up safe on your computer, then you need to format the card in the camera to completely erase it and optimize it. typrice_14.jpg
Nov 09, 2010 | Nikon D70s Digital Camera
I have a Canon EOS 400D. Photographs are appearing with what looks like round marks or bubbles in the image. I've cleaned and changed the lenses but it still appears. I am wary about cleaning inside the...
There is a mode in which you can lock up the mirror and shutter blades so that the sensor is exposed. Use a appropriate cleaning kit and avoid touching the sensor.
Jan 01, 2010 | Canon EOS 400D Digital Camera
Error 99 comes while taking photographs
This could well be a serious issue, which you'd need to send to your manufacturer to fix, however there are a few things you could try first:
Take your lens off and with a clean rubber (like on the end of a pencil), clean the contacts of both the camera and the lens.
Apr 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Microsoft lifecam vx 3000 freezing
Try the cam with another messenger. MSN sometimes has bandwidth issues and cams freeze up.
Mar 06, 2009 | Microsoft LifeCam VX-3000 Web Camera
Very blurry pictures on a Cannon Xti 400D
If u had took photo in very low light, pictures will appear blur. Or if you use tele zoom, u need to use tripod to stablize. In normal conditions, you can turn on image stablizer.
Feb 12, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My camera is a Canon 400D. I put an external flash on it just few moments ago (canon speedlite 580EXII) and the flash wouldn't go off when i took pictures. So i took the flash off, but now the flash on the...
Hi Chrissy, I had observed the same problem - after an external flash had been removed from the camera, internal flash didn't pop up. Tried to look at the Google and finally found the solution. It helped me and could help you as well:
The usual reason is that the camera thinks that there's an external flash mounted on the hot shoe. Check the external flash detect switch. It's located under the right side of the shoe (there is a metalic piece which is kind of "elastic". Just try to push it and release several times, may be put the screwdriver softly under it and out... It helped me. Here is the picture of location of the detector.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Camera freezing
try a new memory card. also try to reformat the memory card. dont take images you care about until resolved.
i would try to remove the battery for about 10 seconds, and then reinstall, then reformat the memory card. if you still have the same issues, replace the memory card. it that does not cure it, you have a warranty repair to manage.
good luck
mark
Dec 23, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Panasonic LUMIX DMC FZ50 Vs. Canon EOS 400D
When it comes to DSLR, Canon scores better than Panasonic. Have a look at dpreview.com for pic samples from both the cameras.
I own a 350D for the last 2+ years. I havent come across any maintenance costs. However, the urge to upgrade is always there :)
- Ranjit
ranjit@supportminds.com
Oct 24, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
155 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
