Question about Hitachi 42PD3000 42 in. Plasma Television
Sometimes it will not turn on. I hit the remote
Sometimes it will not turn on. I hit the remote and you hear it start up, but the stand by light goes from red to no light and there is no picture or sound. So I give up then try later and it works as normal. I thought it could of over heated but when I checked the box and back of Screen it was cool to touch.
    President:
  • 1,099 Answers
the problem is of dry soldering in the power stage of the printed circuit board , open the back of the television and check for dry soldering. resolder if found.
And if otherwise try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 01, 2010
HI, MY NAME IS S. A. ANSARI, I HAVE A SHARP AQUOS LC-32A66M LCD TV. ONE DAY SUDDENLY GOES INTO STAND BY MODE. NOW WHENEVER WE TRIED TO TURNED IT ON, IT ON FOR 30 SECOND I.E. WE CAN SEE PICTURE, HEAR SOUND...
Hi Ansari
It sounds like a main board problem. The control voltage that goes to back-light inverter board; from the main board, goes down. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Feb 27, 2014 | Sharp LC-32A66M 32 inch Multi-System Full...
Tiger Triumph 885i '99 won't start. Has been standing for about 1 1/2 years. Lights turn on but all I hear is a click and it goes dead. Tried all the possible solutions. Any other suggestions?
batt is low--shud always be 12.6volts for ignition-charge or replace--try using jumper cables from a car-u cud gidit started and will idle ruff til it strengthens
Nov 18, 2012 | Triumph Motorcycles
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Sound goes out for certain programs or commercials on different channels, but not all of them
Check your tv's audio settings. If there is an "SAP" button on your remote try hitting that. It stands for secondary audio program. Most manufacturers put it near the corners of the remote leaving it prone to getting hit without knowing. Most shows are broadcast with a spanish version of the audio. Hitting that button should allow you to hear it, but some tv networks do not broadcast the SAP audio making it seem like there is no audio. It usually affects more than one channel, and commercials do not broadcast SAP either.
Jan 20, 2010 | JVC AV-56P575 56" Rear Projection...
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Trouble switching on from stand-by from remote?
You should have a 1 year warranty if purchased new. Probably the main board.
Jun 23, 2008 | LG 32LX3DC 32 in. LCD HDTV
ESA 42" plasma will not turn on
Find a power supply that was the problem with my. Exept my tv now dont have picture Cause ysus board is dead..
Nov 10, 2007 | Televison & Video
Trisonic ts-rc488
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY JAC1NJ@AOL.COM , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Aug 19, 2007 | Trisonic TS-1666RFS Remote Control
No startup
For my FTR9965, it is necessary to physically unplug the
power cord from the box before you are able to enter the service codes. The sequence is:
1. Unplug the box for a few seconds.
2. Plug it in again.
3. Turn on the box with the front panel power switch. Wait for the green light to come on.
4. From the remote, quickly enter 062596 plus the info key.
5. A message comes on the monitor warning you that you could really screw things up if you don't know what you're doing, and do you really want to continue? If yes, hit any button on the remote. You only have a few seconds to respond.
6. The "stand alone" option is near the end of the "service" menu list. When you find it, change the "no" to "yes".
7. Go back to the main SAM menu, scroll down to "Store", and hit OK. I'm assuming this makes the "yes" selection permanent.
8. Enter "00" to exit SAM.
Aug 08, 2007 | Philips E-Box FTR9965 DTV Receiver
Hitachi 42PD3000 42 in. Plasma Television Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
