Question about IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop
How to fix the 2 beep 8 beep then blank screen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 99 Answers
It seems that your RAM of the computer is being pampared. Just reinsert the ram and this might solve your problem. But amake sure that it is inserted properly and unforcefully.
Posted on Jun 01, 2010
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
3 Short beep and 1 long beep and blank screen. My
That means there is s problem with the RAM on the motherboard (Problem lies with the Memory Chip). This could be a result of a Memory chip that has not been inserted properly or it has moved away from its contacts on the motherboard. This will be fixed by opening up the RAM compartment and remove the memory chips and replace them back carefully. Try to switch on your laptop again. Make sure that when you are doing all this, the computer is off and the charger is not connected to it. This I hope will solve your problem.
Aug 29, 2013 | Lenovo Computers & Internet
My e525 laptop starts up, and after the big "e" logo the screen goes blank.* Whenever I press a key there's a loud beep. How do I fix this? *As far as I can tell the screen is blank, but it's...
Try this... 1. Remove the battery 2. Remove the memory for about 5 minutes 3. Re-insert the memory 4. Press ESC for about 3 minutes while putting the power adapter. 5. Then turn on without battery.
Mar 11, 2011 | Acer eMachines 520-2890 Notebook
Our old Toshiba 3560 copier starts up for about 1 or 2 seconds when turned on, but then the screen flashes blank, and I hear 4 beeps, and that's it. I can't figure out what to do with it, as there are no...
Our old Toshiba 3560 copier starts up for about 1 or 2 seconds when turned on, but then the screen flashes blank, and I hear 4 beeps, and that's it. I can't figure out what to do with it, as there are no error messages. Anyone?
I just had the same thing happen to me. Is there a fix for this?
Oct 27, 2010 | Computers & Internet
One long beep and 2 short beeps
Depending upon your BIOS manufacturer, generally this POST error code means either a video card problem or a motherboard problem. If the RAM is OK then you have a motherboard problem, and this may not be cost effective to fix. Consider putting your money towards a new laptop, remove the hard disk and put it into an external USB adapter case and use it as an USB hard drive for backup etc.
Jun 27, 2009 | HP Pavilion zd7020US Notebook
Hp computer beeps and blank screen what cud be the
Check to make sure the new memory and processor is seated in the slot correctly. If either is not inserted fully it will cause the PC to beep and blank screen as your is doing. If that doesn't fix it your memory could be the wrong type or to large for the PC to recognize. JQ
Jun 09, 2009 | Abit Motherboad (ABTKV7) Motherboard
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
At POST gives off 2 short beeps
If you feel comfortable reseat any cards in the pc. Also unplug and reseat the ram. Make sure the power is disconnected from the Plug in the back and you discharge yourself by touching the metal on the case.
Concentrate on reseating the video card as the 2 beep codes is usually the Video card
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wont boot just has series of beeps
Table 2. System Beep Codes
Beep Code Possible Cause Corrective Action
1 Memory refresh failure Reseat the DIMMs.
2 Parity cannot be reset Reseat the DIMMs.
3 Memory failure within the first 64 KB of memory Reseat the DIMMs.
4 Timer not operational See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
5 Processor failure See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
6 8442 keyboard controller error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
7 Processor exception error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
8 Video display memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
9 Optional ROM checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
10 CMOS memory error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
11 BIOS checksum error See Chapter 7, "Getting Help," of the Reference and Troubleshooting Guide for instructions on obtaining technical assistance.
Jan 11, 2008 | ASUS K8V-MX Motherboard
IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop Logo
122 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
