Question about Lexmark T640 Laser Printer
91700 Service Transfer Roll was appearing on my screen so I ordered a new one replaced it and it is still showing me the error.
  • Official Brand Answer
  • 3,344 Answers
Here's an article in the Lexmark website to guide you on what to do when having 917.00 Service Transfer Roll error. Just click on this link: http://bit.ly/d7uyzZ. Follow the instructions carefully. Basically, when having this kind of error, you will need to primarily change the transfer roll or the High Voltage Power Supply. If this doesn't help, it may require service to replace the system board assembly, transfer roll left and right arm.
Posted on Jun 02, 2010
How I fix the error 917 service transfer roll
Try replacing/reseating transfer roll.
  1. The right and left transfer arm assemblies
  2. The high voltage power supply (HVPS)
  3. The main engine/system board
Feb 18, 2015 | Lexmark E350d Laser Printer
How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Feb 02, 2015 | Konica Minolta Bizhub C550
Service transfer roll
Hi, The transfer roller is the roller located untherneath the tonercartridge. Partnumber 40X0130
Oct 18, 2013 | Lexmark T640 Laser Printer
917.00 transfer roll
The cuase is the HVPS card. Clean it or replace it.
Mar 30, 2012 | IBM Infoprint 1552n Printer
I received an message 917.00 service transfer roll. How do I fix this ?
Here's an article on A 917 or 917.00 Service Error Is Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Just click on this link: http://bit.ly/aQD8jS. Follow the recommended actions. If error won't clear, printer may require service. Don't hesitate to contact Lexmark technical support for assistance. Thanks.
Aug 06, 2010 | Lexmark T640 Laser Printer
Error 917 - Service Transfer Roller. I have replaced the transfer roller on my lexmark e350d, but I am still getting the error. Not sure where to go at this point.
Hello my friend.First maake sure the printer is powered off before making any checks on the transfer roll or associated parts for personal safety and to prevent damage to the printer.
1.Check the transfer roll for any signs
of toner buildup, surface damage to the roll, oil or other contaminants on the surface of the roll. Replace the transfer roll as necessary.
2.Check the left transfer roll arm
assembly to make sure it is fastened and locked in the down position. If the arm is not locked down, check to ensure the arm is not broken and will lock into the EP frame correctly.
Check the left transfer arm assembly spring for proper operation.
3.Check the right transfer arm assembly to make sure it is fastened
and locked in the down position. If the arm is not locked down, check to make sure the arm is not broken and will lock into the EP frame correctly.
Check the right transfer arm assembly spring for proper operation. For any background problems, check to ensure the
contact to the HVPS board is correct and that there is approximately 0ohms resistance between the transfer roll shaft and the HVPS contact.
4 . The voltage changes from +24 V dc with the printer idle to 0 V dc when the printer runs the print test. If the voltage is incorrect, check the continuity of line J10-3 in the front
cable harness to the HVPS. If there is no continuity, replace the cable harness. If there is continuity, replace the HVPS. If the problem continues, replace the engine board.
Feb 08, 2010 | Office Equipment & Supplies
HI,when I print , the printer do some label , after go in pause mode automatically message=" = continue = reprint" but after 1o label , the printer give a second error "out of ribbon" .Can you help me...
Hello
After many efforts I have found that in the new PX6i models, the "transfer ribbon mechanism" (the wheel that is responsible for making the ribbon roll) appears to be defective. What happens is that when rolling back in order to keep the ribbon stretched, instead of stopping at the fixed point, it continues to roll back a bit. After a few prints, this causes an "out of ribbon" error.
The solution: replace this part with a VALID part (a new one).
Pavel
Feb 08, 2010 | Intermec EasyCoder PX6i Thermal Label...
Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Nov 12, 2009 | Epson AcuLaser C2600N Printer
Error code 917.00 "service transfer roller" won't clear
This is a transfer roll error. Take the toner cartridge out and clean the area under it. The transfer roll is a roller which is right under the toner cartridge. make sure the ie is clean . It may need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 30, 2009 | Lexmark T640 Laser Printer
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
Lexmark T640 Laser Printer Logo
2,672 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
