Question about Epson Stylus C46 InkJet Printer
Have flashing lights from Green to Red with no
Have C46 flashing lights from Green to Red and back continuously with no option to clear paper or ink which both seem fine anyway, any suggestions please or is it terminal.Del.
    Scholar:
  • 117 Answers
Sounds like a maintenace pad problem (every Epson printer has a different set of flashing lights to indicate this "Maintenacne request"- read this link: http://www.epson.com/cgi bin/Store/support/InkPadsForm.jsp
Posted on Jun 01, 2010
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Both the green light and red light on the top of printer are flashing. There is ink in the printer but it will not print
1 st clear all pending print jobs by In run window type services.msc and the go to print spooler option just stop and restart the service.
make sure there is no paper jam or out of paper massege coming.and when you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center
Nov 24, 2009 | Epson Stylus C46 InkJet Printer
Green light flashing and red light flashing alternatively. Ink cartridges appear to be full. No print
Cek status monitor ? Service required / end life? Use SSC utility to reset wate ink counter.Menu protention counter. Show cuurent value for checking. If value exceeded maximum, reset protection counter. Or Clear counter overflow.
Jun 30, 2009 | Epson Stylus C46 InkJet Printer
MY EPSON STYLUS C46 WONT ACCEPT THE BLACK INK WHICH IS NEW THIS IS THE SECOND ONE. THE RED LIGHT FLASHES AND THE GREEN LIGHT STAYS ON
Check status monitor? Black ink not recognized or what? If not recognized, red light just on. But flashes? It's may ink nearly out (low level ink) or printer need service. Check it. using SSC utilty to resolve. Reset protection counter and clear counter overflow.
Jun 27, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
Paper in correct turned printer on red light flashing and will not print paper is blank when it comes out.
Red light flashing, do printing, paper blank out : ink low message. Ink level low, near to ink out level. But it just program, may be ink tank is out actually (no ink at ink tank). Refiil ink tank or replace w new one. Check Nozzle.
Jun 11, 2009 | Epson Stylus C46 InkJet Printer
Epson c46 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
INK REFILL
get a new printer...this one is truly unhappy
Jul 29, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
555 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
