Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell monitor back removal
The on/off button is jammed off. How do I remove the monitor cover on the border to access the button. It a standard Dell 17" ultrasharp monitor (4 screws in the back)
  • 472 Answers
This can go one of 2 ways..very easy or very hard.
Having said that here we go.
  • Get a towel and lay it on a flat surface.
  • Remove the 4 screws from the stand and remove it.
  • looking from under the monitor you should see 2 small notches between the front and rear covers.
  • Carefully insert a flat blade screwdriver (not too far) into the hole and lift upwards. It should pop. Do the same on both sides.
  • Carefully pop it all the way around (without using anything but light pulling pressure.)
Hope that helps =)
Posted on Apr 09, 2008
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
Carriage jam on 926 dell printer
Here are some steps that can resolve your issue about paper jam.
Try to lift the paper exit tray, then remove the papers, then lower the paper tray and press the select button in the printer. If still the same, Raise the printer unit and check if there's a paper jam then try to remove it, close the printer unit and push the select button. If still the same try to open the access door in the back of the printer, remove the paper jammed, close it then push select button.
For more information about step by step procedure with visual click on the link.
Hope this will help your issue.
Thank you for choosing fixya
Mar 03, 2011 | Dell 962 Photo All-In-One InkJet Printer
Hi, My hp k550 is blinking at lights 1 and 4. How can I fix this problem please? Thanks
Issue
The power light and resume light is blinking.
Power light and resume light is blinkingc01576793.gif Solution one: Press the resume button
Load paper in the paper tray and press the resume button (c01219285.bmp ).
Try to print the job. If the issue continues, proceed to the next step.
Solution two: Clear the paper jam
Step one: Clear the jam from the back and top of the product
  1. Remove any paper loaded in the output tray.
  2. Turn off the product.
  3. Push the button on either side of the rear access panel or duplex unit and remove it. Figure 7: Removing the rear access doorc01576794.jpg
  4. Locate any jammed paper inside the product and pull it out towards you.
  5. If there is no jam, push the latch on the top of the duplex and lower its cover. Figure 8: Lower the product coverc01576795.jpg
  6. If the jam is there, carefully remove any jammed paper and close the cover.
  7. Replace the rear access panel or duplex unit.
  8. Open the top cover.
  9. Check for and remove any jammed paper by gently pulling it out.
  10. Make sure that there are no scraps of paper stuck between the rollers.
  11. Close the top cover, turn on the product, and resend the print job.
Try to print the job again. If the issue continues, proceed to the next step.
Step three: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Cause
The product might be out of paper or there might be a paper jam.
Feb 28, 2011 | Office Equipment & Supplies
Someone fixed my computer an now there is a border around the screen. How do I remove it?
reset the screen{Video} resolution 124/728 and the border should be gone
Jan 11, 2010 | Dell E228WFP LCD Monitor
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
My monitor on/off problem. where to repair.
You will have to remove the cover and replace the button.There is no other fix for this but to replace the button.
Good luck
Oct 20, 2009 | Dell Computers & Internet
Dell Studio 15, CD stuck in slot
remove drive out there's 4 screws below drive remove them, you should be able to open drive in 2 bits remove cd put all back together ;)
you may have 1 or 2 more screws just remove them to open drive in 2.
www.e-repairs.co.uk
Jul 04, 2009 | Dell Studio 15 Laptop
I have a black border on top of my screen
There are two things which could have caused this. One, the Monitor settings have changed or the computers display settings have changed.
1. Resetting the monitor to default.
Push the 'MENU' button to open the OnScreedDisplay system and display the main features menu. Push the - and + buttons to move between the function icons
Use the buttons to highlight 'Factory Reset' (this returns the settings to the factory preset values for the selected group of functions)
Detailed instruction available at http://support.dell.com/support/edocs/monitors/E153fpb/En/controls.htm
2. Checking the desktop display settings.
Right click on the desktop and select properties, click on settings and make sure screen resolution is set to one of the following 640 x 480 or 800 x 600 or 1024 x 768. These are the only ones supported by the monitor
If both this fails. Then the monitor is nearing end of life
Mar 02, 2009 | Dell E153FP 15" LCD Monitor
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Dell UltraSharp 1907FP 19" LCD Monitor Logo
1,042 people viewed this question
Alun Cox
