Question about Linksys Wireless-G WRT54G Router
Wireless-G USB Network Adaptor
I got a new computer. We went from Dial-Up to Verizon FIOS. I would like to use the old one to access the internet in another room, however the CD/DVD player is broken on it, so the installation drive tha went with the hardware will not work. I tried using a flash drive to copy it, but it will not install. Help.
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
My toshiba laptop has problems connecting wirelessly to verizon fios, they claim it is my internal wireless card because my other computers can connect. How can I fix this?
There are some wireless card which doesn't support verizon fios.Check out if your Card is supported or not.if not supported ask their Customer service for a USB wireless Card Brand and its specification which with work fine with verizon fios.
It will solve the problem.
Dec 29, 2009 | Toshiba Satellite A105 Notebook
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
My wireless connection won't work
Those pieces if data come from your FiOS gear. On the bottom of the FiOS Wireless and network set, is a serial number, and associated with that is another number, call it your password, but together they are the profile and Password with which you gain access to the FiOS Network, to allow you to get out to the Internet.
Check all installation papers you got from Verizon, as that information should be there, or call their help line. They are usually pretty good in helping you and FiOS is not off-shore, so you will get a good response.
Jul 01, 2009 | Computers & Internet
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
Inspiron 6400 wirless connection
HI
If the browser shows working offline and wireless is connected fine then it could be an issue where work offline is checked in the browser.
In internet explorer 6 its found on File in the menu, if work offline is already checked, check it again to remove the check mark and then try, if its internet explorer 7 its found on tools, the same steps and in firefox under file,
Also try this step as well, if its internet explorer go to tools-internet options-and in internet options-go to connections tab-there is dial up and networking box-remove the dial up connections from the box-and check the one never dial a connection
also check the firewalls and antivirus programs, post your results.
thank you
rakesh
Jan 11, 2009 | Dell Inspiron 6400 Notebook
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
To: Verizon Central Many Problems: Please help! I have Verizon Fios for my television and Internet. (1) I am unable to access the Internet online on my laptop. That's the first problem. (2)I have...
Verizon Fios Fiber Optic Television http://www22.verison.com/residentialhelp/
Verizon Internet and Verizon Wireless Internet
Verizon | Yahoo!
Verison | AOL
Verison | Live
Verison with MSN premium
Verison Online
Vonage Phone number suggests to me a that you have been sent a ( Router )
Check to see that your particular router supports wireless
If wireless is supported on your router you may wish to contact verison over the phone for farther instructions.
Selah :-)
Sep 14, 2008 | Computers & Internet
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Mar 28, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys Wireless-G WRT54G Router Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
