Question about Xerox WorkCentre M15i Laser Printer
Scanner locked error message of scanner locked and don't know how to unlock
Look where your copies come out and there is a switch on the top underside, (green on the M20i) and make sure it is in the unlocked position. You may need to wiggle the switch to fully unlock it. Mine was locked but I was able to re-engage flipping the switch several times.
Posted on Jun 03, 2010
Why do I get an error message: Internal error occurred. Scan driver will be closed. Code:5,202,52?
Look at the bottom of the scanner and there should be a lock/unlock slider. Unlock it and see what happens.
If it is already unlocked then the drive/stepper motor or belt is bad.
Mar 27, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
Bizhub C35 unlock scanner
REMOVE THE LOCK , SEE UNDER THE SCANER UNIT
May 01, 2014 | Office Equipment & Supplies
I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
My 5800 keeps telling me to unlock it when I click scan, but I can't find the lock anywhere.
The 5800 scanner does not have a physical lock switch. DO NOT attempt to open the scanner and unlock the hardware. This could be either a hardware failure or software
Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
Ensure you are using the correct power supply for your scanner. If you are using a power supply that has the incorrect DC output, you will get a scanner locked error message. This flatbed scanners has I believe 100-120V AC input and 12V DC output.
Plug the power directly to the wall, not a UPS battery back-up, power strip or surge protector. Power fluctuations from a UPS battery back-up, power strip or surge protector may be causing this error. If all this fails try reinstalling the scanner driver
Aug 18, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Unlock
Most scanners shipped have a lock on them to prevent the top from opening up and damaging the glass. This is a screw type mabey other but a penny fits in mine. This may not be the case for you but look in your manual to find the unlock device.
This will also in some scanners prevent the stepper motor from moving in transit . The stepper motor is the device thats makes the bar slide up and down to scan the page.
Hope this helped some.
Kevin
Dec 30, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Error Message
The scanner lock is used to keep the printer from being damaged when it is being shipped. To unlock it, just open the printer and push the scanner lock down. When you lift up the scanner unit, (like what you do to get to the cartridges) the scanner lock is on the left of the underside of the scanner unit. You can get the manual from the Lexmark Website at http://www.lexmark.com/publications/eng/x6100/index.html
Sep 17, 2007 | Lexmark X6170 All-In-One InkJet Printer
Xerox WorkCentre M15i Laser Printer Logo
630 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
