Question about Canon PowerShot A550 Digital Camera
Low battery all the time
My Canon Powershot A550 shows the low battery signal even when I put new batteries in. The lense continuously closes and the camera shuts off even with new batteries. What's going on?
Remove one battery after using your camera..install again when taking more photos. This solved my draining battery problem.
Posted on Aug 14, 2010
    Novelist:
  • 82 Answers
This is not a good signal. you can make this prove. clean the internal camera contact with a specific contact spray and one cotton fioc
ore you can use normal denaturated alcohol. this is one possibilty. if you dont have any betterment. its probably that the camera have a eletronic defekt. this is not so uncommon with old camera. the camera have internal fuse the works not good and gives this problem. motherboard defekt. good luck i hope for you that is only a dirty contact faulty.
paolo
Posted on Jun 01, 2010
I have canon A550 and i had the same problem like u. i just bought rechargeable sony batteries and when i try to use says CHANGE BATTERY. I tried the solution from up above with the alcohol and still not working, the solution is simple.
the cam has also a small round and flat battery (looks like the battery of wrist watches), and i removed it. i turned on the cam again and the battery is full and i dont have to change it. now i just have to go buy that small round flat battery and replace the old one because that battery keeps the date and hour on the cam. TELL ME IF WORKED
Posted on Apr 13, 2011
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
Apr 18, 2011 | Canon PowerShot A495 Digital Camera
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
Low battery indicator
Dear sir,
Welcome to Fixya Customer Support
By analysing your problem it deffinately due to battery power sensor problem.so you can visit nearer canon camera service centre,they replace the sensor.
good luck
Fixya Customer support
chandrashekhar
Jul 17, 2009 | Canon PowerShot A550 Digital Camera
Canon a550 reads low battery even when i put in new batteries
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 23, 2009 | Canon PowerShot A550 Digital Camera
My canon powershot A550 camera behaves as low battery with new b
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Apr 11, 2009 | Nikon COOLPIX L18 Digital Camera
No battery life
If you have changed to new batteries and it still shows low battery warning, the camera may need the repair service.
Here is the information from Canon's support page.
Batteries do not last very long in camera (You will need to copy and paste the title on the search field)
"Solution: The PowerShot A550 requires service.
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below: ..."
Jul 10, 2008 | Canon PowerShot A550 Digital Camera
Canon PowerShot A550 Digital Camera Logo
1,084 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
