Question about Bosch Washing Machines
Water not flowing into machine.
I have a Bosch Exxcel 1400 express WFX 2868 which is nearly 5 years old. We have had an error message F02 which according to the manual means that water is not getting into the machine. We have followed all tips in the manual such as checking for kinks in the inlet pipe, disconnecting the inlet pipe and flushing through the filters (which showed no signs of blockage) etc and this has not solved the problem. When a cycle function is selected a quick spurt of water goes into the machine and then the fault message appears. Do you have any suggestions?
    President:
  • 1,554 Answers
Check the operation of the water inlet valve by using a cheater cord. Disconnect the wires from the valve solenoid terminals the connect the cheater cord instead then plug the cheater cord to a 120 VAC outlet. Replace the water inlet valve assembly if water still doesn't flow into the washer; otherwise, check the wiring connection between the control and the water inlet valve. Make sure the wiring harness is in good condition and the terminal connections are clean and snug fit. Reseat the connections several times to clean off dirt and corrosion build up int the terminals and connectors. The control board is malfunctioning if the water inlet valve works fine with the cheater cord and the wiring harness and the connections are in good condition.
Posted on Jun 01, 2010
I have a Bosch Exxcel 7 1400 express, had F21 error which I cleared but now when set to wash, water comes in but the drum doesn't move.
F21 refers to the carbon brushes in the motor so price new brushes - if you are handy they are easy to fit and not expensive - but if you can't do it yourself i personally wouldn't spend too much on repairing a 5 year old machine
May 04, 2014 | Bosch Washing Machines
My bosch exxcel 1400 express will not spin
take out plug first check the motor carbon brusher are not worn
Dec 03, 2013 | Bosch Exxcel WFX 145S Front Load Washer
Exxcel 1400 s express washing machine key light is on cannot use . or find operating manual help
pick the last program you put on ????
then you hold the button with the clock on it for five seconds the lock should now be off
please leave feedback if it helps
Jan 06, 2013 | Bosch Exxcel WFX 145S Front Load Washer
Bosch logixx 1400 express washing machine spin is not working . ALSO THE WATER IS NOT BEING DRAINED OUT IN THE NORMAL CYCLE
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Apr 10, 2010 | Bosch Exxcel WFX 145S Front Load Washer
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Bosch exxcel 1400 s express fault F01 and F02 whats the problem here?
F01 Door not closed properly.
F02 Tap not turne on, Inlet hose kinked or pinched, Filter blocked in water inlet hose, Water pressure to low.
Apr 30, 2008 | Bosch Washing Machines
Washing Machines Logo
65 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
