please shut down the device for a few 10 minutes and retest your device. If issue still exists, please perform a factory reset to fix the issue. Thank you.
Sounds like you have a control logic issue. Either a button on the control panel is stuck, or the control board is defective. Find the model number on the unit and post it in the comments please.
different pc has different bios beeps depends on the bios manufacturer, but in your situation it is most likely you have problem with your video device. is it connected in video card or directly plug in the built in video port of the pc? if its connected in video card, remove video card temporarily then connect it to built in video ports, or vice versa, if your in built in video port you can try testing it with video card in pcie slot.
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3
is in standby mode(red light) till you hear a double beep. sometimes
the ps3 does a beep then another beep and goes back into standby thsi
is fine just release the power and quikly press and hold it again till
you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby
again....release and hold power again.......beep .........double
beep...release power now you should be in recovery menu.
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
when ps3 is in standby mode(red light) press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
