I have an HP c4680 Printer, purchased in France four months ago and am now based in Seoul Korea. I have purchased HP Ink Cartridges in Seoul for the C4680 but when installed the printer tells me the cartridge is incompatible but the cartrdige is the HP 60 or HP 60 XL and clearly marked for use on the C4680 printer.
  • 2,069 Answers
Please follow this guide here for further instructions on how to resolve your problem.
Posted on Jun 01, 2010
Print cartridge problem hp c4680
1. remove all the ink cartridges from the printer and then clean the copper contacts with a lint free cloth put it back in and check if that helps..
2. then unplug the power chord from the back of the printer without turning off the printer and then press and hold the power button for 30 sec. then release the button and then plug in the power chord at the back of the printer and check if that helps..
3. try changing the ink cartridges as it might be an issue with the ink cartridges... however if you have already done that then most probably its an issue with the printer hardware.. you should call HP and ask for replacement...
Oct 21, 2013 | HP C4680 All-In-One Inkjet Printer
Hp photosmart c4680
The HP C4680 is a powerful all-in-one printer that combines an easy interface and connection process with powerful printing capability.
With a small time investment and minimal effort, even the least tech-savvy home user among us can have their HP C4680 up and running in no time, and take full advantage of all of its printing power.
Connect the AC adapter from the AC terminal on the upper right-hand side of the back panel of the printer to an electrical outlet or surge protector.
Power on the printer using the power button on the front panel of the printer and specify language and country preferences using the prompt on the main display of the printer.
Remove the pink tape from the print heads on the provided ink cartridges.
The tape should come off easily with gentle pressure.
Install the cartridges by opening the main door on the front of the printer and placing the cartridges into the cartridge cradles.
The HP logo should be facing up. Push the cartridge into the cradle until it clicks into place.
Attach the USB cable from the printer's USB port to a USB port on your computer and power on the printer.
Install the setup CD that came with the printer into your computer's CD-ROM drive and follow the steps for installing the printer software on your computer.
Your HP C4680 is now set up and ready to use.
HP Printer Driver Packages
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
Aug 09, 2013 | Computers & Internet
I bought HP 940 XL some months ago and my printer says the date has expired
What date has expired? Are you talking about the cartridge date? If yes then thats what HP is known best for: Making people buy cartridges all the time. Its said that most cartridges work fine even after their expiration date so you should try resetting the date on the cartridge. This explains it: http://www.ehow.com/how_7354802_reset-hp-940-chip.html
Watch this too: http://www.youtube.com/watch?v=LDH2UcMd7LI
Nov 15, 2012 | HP Hewlett Packard - 940XL Four Pack Black...
Printer Error Message
Yes, there a few items you need to consider with respect to HP 61 (or 61XL) cartridge errors messages on any HP Deskjet 1000 through 3510 printer model:
If you get an HP 61 / 61XL integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore ink low, non-genuine, counterfeit messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of this low ink phenomena.
If the new (or refilled/reman/compatible) HP 61 / 61XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. Ensure you press OK or Cancel up to six times to clear out the printer error log.
These types of severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Test
http://www.youtube.com/watch?v=tMZkqE36ifk
Aug 24, 2012 | HP Deskjet 3052A Wireless e-All-in-One...
C4680 print cartridge problem
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 06, 2011 | HP C4680 All-In-One Inkjet Printer
Carriage jam on HP C4680 printer after putting in new ink cartridges
Have you checked to see if you have a paper jam in the back entrance of your printer. Make sure there are no pecies of paper jamed on the roller.
Jan 20, 2011 | HP C4680 All-In-One Inkjet Printer
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
"incompatible cartridges"
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
HP officejet 6210 all-in one
ok i found a way to help you find those 94's 97's printer cartridges
http://computers.pricegrabber.com/ink-toner/m/3768822/
this link is for the hp 94 cartridge
http://computers.pricegrabber.com/ink-toner/m/3768824/search=hp%2097/st=product/sv=image/
this link is for hp 97 cartridge
from the uk i hope this helped you find the right cartridges
338-334 is there new numbers if there not put in right the cartridges will have error to them kinda snap in with little force
May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Cartridge refilled
Some time it takes days before the printer will register it.
Nov 25, 2007 | HP DeskJet F380 All-In-One Printer
101 people viewed this question
k24674
jasbo
jasbo
