Question about Nokia 3110 Cellular Phone
Why is speed low? - Nokia 3110 Cellular Phone
  • 67 Answers
May be ur mobile affected by virus.connect ur mobile to pc and scan by antivirus..then delete ur images and inbox messages from ur phone..then it will work fast
Posted on Jun 01, 2010
A diesel engin uses diesel fuel generates low power at low speed
Increase the speed for constand power output, or check the load it maybe more than the genset can power.
Apr 03, 2017 | Speed Electrical Supplies
Blower just started staying on - furnace has been turned of for 6 months
This is a diagram of a blower relay and a fan motor, the normally closed fan relay switch goes to the low speed which is the Heat speed, the low speed is controllled by a temperature delay depicted in the low speed circuit.
The normally open fan relay switch goes to the high speed, which is the AC modes speed , also if you run the fan continuously via the fan switch on the thermostat this is also to high speed.
I suspect the temperature delay's on setting is being reached thus cycling the low speed of the fan.
Nov 08, 2015 | Heating & Cooling
Why won't one of the spa motors start at low speed?
bad two speed relay on that motor
Oct 10, 2015 | Pool & Spa
MY PUMP WILL ONLY RUN ON LOW SPEED ( NEUTRAL AND BLACK) . PUMP IS MARKED 230 v , ? DOES THIS RUN ON NEUTRAL TO 120 FOR LOW SPEED AND NEUTRAL TO 120 FOR HIGH SPEED AND USE SEPERATE WINDINGS OR IS HIGH SPEED...
If this is 220v then your netural is not a netural but a common. Meaning it is common 110v to both the high and low speeds of pump. The high and low speed are the same leg of the 220v or the other 110v leg they just separate at the clock or high/ low switch. Then yes they run through separate windings for high and low.
If your not getting high speed it could be the high speed winding but be sure to check your switch and high speed lead first before doing anything else.
Sep 19, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
How do I determine when to yse high speed /low
High spped for drilling
Low speed for driving scrrews.
Sep 05, 2009 | Drills
I have a 2 speed spa motor (K48m2a4) that stopped working at low speed. going to high speed only has circulating power.
Either the low speed circuit is defective or a relay is inoperative. If you feel confident , you could switch the low and high speed leads on terminal plate. The high speed jet button would activate low speed on pump if motor is good.
Aug 01, 2009 | Pool & Spa
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Please explain hyundai terracan 2002 fault codes p1730 front speed sensor low input, p1732,p1734 low input,how to find problem, low range there is no opperation at all, cheers ,clive.ps in the model...
P1730 Front Speed Sensor - Low Input
P1732 Rear Speed Sensor - Low Input
P1734 Speed Sensor Reference - Low
These are all references to Electronic Stability Control or ABS systems. If there's no problem with wiring, then you could safely assume the speed sensors are bad.
Apr 30, 2009 | 2002 Hyundai Tucson
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Nokia 3110 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
