Question about Sharp AR-M237 Copier
I have 2 Sharpe AR266 I am trying to find fuser units for them the AR266 isnt mentioned anywhere its on 110 voltage many thanks Jimmy
  • Sharp Master
  • 12,061 Answers
Http://www.google.co.nz/search?num=100&hl=en&q=Sharp++fuser+units+spare+parts+price%3F&btnG=Search&aq=f&aqi=&aql=&oq=&gs_rfai=
click on that and open in new window, and you will see many many sites to inquire at.
Posted on Jun 01, 2010
Fuser unit voltage, old 110, new 220 can this be right
HI are you in the usa or the u.k. ? If its the USA, 110v, if its the U.K.220v is the right one , Markus.
Jan 11, 2014 | Samsung CLX 3160fn All-In-One Printer
Convert from 110 to 220
The problem you had mentioned is not understandable, but if you need to increase the voltage from 110 to 220, all you need is a step-up transformer.Need to check in your local electronic or electrical shops around.
Thanks
Jun 26, 2012 | Cameras
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Where is the camshaft position sensor on a 1994 gmc jimmy the garage diagnosed that was the reason it was not starting i bought the part for 80.00 and can not find it on the vehicle my haynes manual makes...
on 2.2 engines located on passenger side of engine to access sensor jack up and remove wheel on the 4.3 with distributor or high voltage switch system its located in the distributor assembly--have to remove dist cap and rotor
Oct 28, 2009 | 1994 GMC Jimmy
Air conditioner on 1993 gmc jimmie doesn't blow out cold air. The fan runs however the clutch on the air conditioner unit won't kick in
if clutch isnt kicking in, there only could be two things.....electrical issue(test the clutch connector for voltage, relays etc.), or low or no freon(have it vacuum tested if voltage is fine). Hopefully this helps
Aug 16, 2009 | 1993 GMC Jimmy
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
Nov 04, 2008 | Samsung CLP-510 Laser Printer
"Cannot Adjust Fusing Unit"
The transfer belt needs to be replaced.
May 01, 2008 | Ricoh Aficio AP3800C Laser Printer
Sharp AR-M237 Copier Logo
277 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
