Question about Gaggia Classic Espresso Machine
Gaggia classic not pumping
Not pumping
  • Gaggia Master
  • 1,711 Answers
Propably the vibrating water pump is the problem.
It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Posted on Jun 05, 2010
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Gaggia Classic coffee pump does not function properly
Use the bottom pic for help.
Posted on Mar 04, 2010
espressonist
  • 1711 Answers
SOURCE: Hi, My Gaggia Classic is not working. No water
Good luck
Posted on Jul 01, 2010
SOURCE: Is vinegar OK to descale a gaggia classic?
1:2 solution vinegar to water should do the trick; rinse thoroughly!
Posted on Jul 04, 2011
Pump won't prime
Needs De Scaling. Franko
Dec 31, 2013 | Gaggia Classic Espresso Machine
Gagging espresso maker does not pump water
Hi There,
It's either the pump or the solenoid.
When you turn of the coffee switch after there should be a discharge into the water tank - if this happens - the solenoid is blocked but the pump is not.
It is an easy fix.
( This happens when the machine has not been descaled and the solenoid is blocked.)Usually its not the pump.!
Vibration pump Gaggia Saeco Gaggia classic solenoid
Oct 17, 2017 | Gaggia Baby Coffee Makers & Espresso...
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Who sells the Eaton pump for a Gaggia Classic?
You can get ANY brand of vibration pump, Just make sure is the same ELECTRICAL configuration. Like 24V or 120V, same for HZ. and Watts.
Jan 15, 2011 | Gaggia Classic Espresso Machine
Gaggia classic light not working
You state there is no lights, but does the pump work? If there is not power at all (no pump & no lights) then the problem is most likely the thermal fuse. Radio shack sells these and the barrel clips to attach. Will cost no more than five dollars for everything.
Michael Ventura Laguna Beach
Jun 07, 2010 | Gaggia Classic Espresso Machine
Hi. My Gaggia Classic doesn't prime. The pump makes a noise, the boiler gets hot but no water is sucked up out of the reservoir - please help!
I have a Gaggia Espresso maker and to prime it I have to remove the reservoir and use a tall glass next to the machine so that the hose is almost flat. It seems to **** the water up easier that way. Good luck.
Apr 11, 2010 | Gaggia Classic Espresso Machine
Gaggia classic
I can deliver it for you. Only I live in Europe and then you have to pay shipping to.
Let me know!
Marco
The Netherlands
Aug 24, 2008 | Gaggia Classic Espresso Machine
Gaggia cffee machine will not pump water through th coffee
my gaggia coffee machine, will not pump water trough the coffee. I see the water going back in the reservoir. I used the cleaner cafiza, but no help. Please help.
Thank you
Jul 06, 2008 | Gaggia Classic Brushed Stainless Steel...
Gaggia Classic Espresso Machine Logo
427 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
