Question about HP Pavilion dv1000 Notebook
I have a dv1000 that has no power, no lights, basically nothing. Replaced power supplies and batteries. plz help. Any common problems that have those symptoms?
  • HP Master
  • 12,061 Answers
H10032.www1.hp.com/ctg/Manual/c00444244.pdf
http://repair4laptop.org/disassembly_hewlett_packard.html
These two links should help you sort it all out.
Posted on Jun 01, 2010
Amilo pa 2510
It could be anything, Start with the basics. You may have a power problem Try removing the battery, and run with just the supply. Is the supply OK? Is the battery charging?
May 14, 2014 | Computers & Internet
Hp dv1000 does not power up
maby the charger is not compatible with your laptop.
Aug 25, 2012 | HP Pavilion dv1000 Notebook
Hp dv1000 screen does not show anything
there is a common problem with these laptops the motherboard faults if the power led lights up but nothing else then that the problem
May 28, 2010 | HP Pavilion dv1000 Notebook
Hi. I returned from vacation and turned on my power strip and monitor, tried to start my emachine t5026 computer and got nothing. the power light on the back of the power supply is off. If I unplug or...
Your Power supply is most likely dead.
A power strip is not sufficient protection against black outs, brown outs, power surges and other electrical interruptions that occur in the house. Many PC components are very sensitive to fluctuations in power and power supplies often are among the first casualties when a serious problem occurs.
To protect yourself against these common power issues you should invest in an Uninterruptible Power Supply or UPS. A UPS is basically a battery backup that will provide power when brown-outs or black-outs occur and will protect the delicate electronics in your PC. You can purchase them at most stores that sell computers and components.
Nov 10, 2009 | E-Machines Emachine T5026 power supply **...
My Dell dv1000 has completely died
You are listing this unit as a HP and stating it is a dell.???
Nov 06, 2009 | HP Pavilion dv1000 Notebook
Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Oct 18, 2009 | HP Compaq nx7300 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Dv1000 power problem
This is a common problem we faced especially for home users. The problem is really simple: The power adapter socket on your laptop's motherboard is broken. Assuming that the system board is not broken or cracked, this broken socket can be easily replaced. And it only costs $2!
Unfortunately, it is common policy for service centers nowadays to replace the board for this type of problem, thats why they are charging $398, which is actually a good price.
If you have any basic electronic background, then you can replace it yourself. The main hurdle you will face is in finding the exact dc socket and disassembly and assembly of your notebook. Just remove and replace the defective socket from the mainboard. Otherwise you can put external connector on it. It might not look good, but you do have a working laptop now.
Regards
Nov 13, 2008 | HP Pavilion dv1000 Notebook
Powermac g4 will not turn
this is a common problem with G4 Quicksilver. Your power-supply is defect and has to be replaced. I have 4 G4s in my lab with the same symptom: a short flash of the power-button light, sometimes it turns on, but mostly the machine is dead.
Richard
May 07, 2008 | Apple Power Supply 344 Watt PowerMac G4...
HP DV 1000
1) plug YOUR power adapter into your friends hp dv1000, see if it turns on laptop.on. If yes, then u have one less problem.
2) to trouble shoot a laptop takes a lot of skill, stuff is very small, things could be damaged just by pulling the wrong way. you would HAVE TO BE very carefull.
Look for the trouble shooting manual 1st. or find a good technical person.
May 05, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
