Question about Toshiba Satellite A60 Notebook
Why does my toshiba laptop shut down when its idle?
Its not coming on now but its charging, i dont understand whats wrong...
  • ekaa2000566 Jun 01, 2010
    thanx, i removed the battery but still not coming on...please how do i do the RAM thingy?
    Novelist:
    Champion:
  • 256 Answers
While you are accessing the Internet, a large number of temporary files get created. These temporary files consume large amount of memory space in your Toshiba Satellite laptop. This automatically reduces the speed of your Toshiba Satellite laptop. By using system utility, temporary folders can be removed to fix the shut down issues.
Posted on Aug 02, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Please check the RAM. replace it or swapp together.
Posted on Jun 01, 2010
    Sergeant:
    Champion:
  • 256 Answers
Remove laptop battery and connect adapter..
Toshiba laptop will not turn on without adapter
i think your battery place has something wrong so the electric can go or there is some space between battery and laptop
Dec 13, 2012 | Toshiba Computers & Internet
My toshiba satellite series keeps freezing up when idle and I have to do a force shut done, any suggestions?
Best suggestion is to back up your files and reinstall the OS.
If it freezes while idle, some necessary data is most likely corrupted.
Force shut downs often cause system files to corrupt.
Oct 18, 2012 | Toshiba Satellite L305-S5908 Notebook
My Toshiba Satellite L645D - S4056 Laptop is not charging. When I remove the Battery to try charge it directly the lapop will still not pick charge. Right now i dont know if its the Charger or the laptop...
From what you I can understand the issue is the charger. Without the Battery the Laptop will not work as the Charger is not giving power to the laptop.
If this is the case you require a new charger. I would suggest testing with a similar charger if a friend has a similar model or taking it to you local shop before you spend money on buying a replacement.
Feb 02, 2012 | Toshiba Satellite L645D-S4056 laptop
Toshiba A60 shuts down in 3 seconds
Bios may be set wrong(fix by restoring default settings)
memory may be damaged(replace if true)
battery may be low and system shuts itself off(make sure battery is charged)
Drivers may be wrong(replace drivers in safe-mode)
Motherboard or other devices inside laptop may be loose and/or shorting.(Go to local computer fix-it shop or (open up laptop and check for loose connections which may void warranty.))
My guess is your bios needs resetting
Hope I am a help.
Feb 03, 2009 | Toshiba Satellite A60 Notebook
My Toshiba A135 laptop has totally shut down and will not turn back on
yes44_yes,
If your laptop is only about six months old, I would go to the Toshiba website & register your laptop then Call the tecch support line at (800) 457-7777 most toshiba laptop come with a factory 1 year warranty unless it is a refurbished unit. Then it only has a 30day warranty.
PAeasop
Apr 20, 2008 | Toshiba Satellite A135-S4527 Notebook
Shutting off
First off im affraid you cannot totally rely on ANY software with regards to Thermo sensing
they are only an indication and can be anywhere from 5 to 25 degreeC out, dont get me wrong
generally you can get a good indication but thats the best they can be. Listen for fans kicking in then staying on, keyboard getting warm to hot.
If the machine is just cutting out that would suggest power supply either charger fault etc (is the battery fully charged when it happens) or overheating, if its shutting down the first thing i would try is running in safe mode see how it performs, check for any spyware/virus, run
Hope helps for now let me know
Apr 08, 2008 | Toshiba Satellite 1805-S274 Notebook
My Toshiba Satellie P15-S470 turned off by itself and I can not mak it to run.
Sir:
Is your laptop connected to a power source? If not it needs to be recharged...
Check also the battery of your laptop, it might be dead already... meaning even if it is charging the battery doesn't charge anymore... it may need replacement.
To check the battery... remove it from the laptop and find a flat button to check if the battery is charged, or half charge, or none at all. If below half then the battery needs to be replaced.
Jan 23, 2008 | Toshiba Satellite P15-S470 PC Notebook
Comp shut down
dont even mess with it just send it in you will void the waranty
Nov 03, 2007 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite A60 Notebook Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
