Question about D-Link DES 1024D (DES-1024D) 24x10/100 Mbps Networking Switch
Some loose contact it seems??? sometime able to connect internet and sometimes not possible?? wat is the reason???
  • 108 Answers
D-Link 1024D performace drops when it gets heated.. Thermal problem.. switch off this equipment for few minutes and try.. keep this equipment in proper ventilation
Posted on Jun 01, 2010
When you hit a bump in the road the headlights go out. sometimes for a day sometimes for longer seems to be an electrical connection.
check the bulb sockets it must be loose thats why when its shaken it looses contact and the electrical supply gets disconnected thats why light goes off/ or check wiring connections that controls your light.
Apr 03, 2010 | 2000 Toyota Sienna
No sound
Loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 11, 2008 | Audio Players & Recorders
Eclipse radio model number cd3422 say help when turned on diplays 7a201418
It is a loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 01, 2008 | Audio Players & Recorders
Siemens prisma 2 vc has lost volume
It is a loose connection or cold solder and cleaning problem this is the main caused of no volume..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Good luck:
Regards,
VOTIT
Jul 31, 2008 | Audio Players & Recorders
Denon RCD-M35DAB has tuner drift on AM, tap side of unit on rear righht hand side then ok for a while.
Good luck:
Regards,
VOTIT
Jul 30, 2008 | Denon Audio Players & Recorders
Projector Lamp seems to go out after a few seconds to 1 minute
it seem the lamps are getting heated, do you see the fans functioning properly.
Jul 30, 2008 | InFocus Office Equipment & Supplies
I can get no sound from my hitachi AX-M80 CD system
Good luck:
Regards,
VOTIT
Jul 29, 2008 | Audio Players & Recorders
Hi my pioneer SU-X950's volume keep going up and down on its own! help Thanx carl
Loose connection or cold solder and cleaning problem this is the main caused..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Good luck:
Don't forget to rate;
Jul 20, 2008 | Pioneer Audio Players & Recorders
Amp keeps clicking
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Jul 15, 2008 | Sharp Audio Players & Recorders
Speakers very soft can't hear woofer
Good luck;
Jul 15, 2008 | Audio Players & Recorders
D-Link DES 1024D (DES-1024D) 24x10/100 Mbps Networking Switch Logo
147 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
