Question about Bernina 1008
My Bernina 1008 is stitching super slow. This happened once before when it had been left in a cold room, and started running fine after warming up. But this time, the warm-up doesn't seem to have changed anything. I hadn't used it for about a month, and it was sitting in a cold laundry room during that time. I tried cleaning and re-oiling the hook, but it's still running super slow, like it's struggling to move up and down. Any ideas?
RickE1
  • 202 Answers
SOURCE: Timing for Bernina Virtuosa 153
Timing these machines gets pretty involved such as in just removing the covers. You need a grounding ******** your wrist as the cables all need to be unplugged and you don't want to send a static charge from yourself to the circuit boards. They are expensive. Then you need special sized metal pins to pin several pinning points so the needle, hook, stepping motors and feed dogs all co-ordinate with each other. Also several places need certain guages to set less than .1 millimeter size distances between different places to avoid other problems. You also need several sized torx screwdrivers and the knowledge to adjust the upper and lower tensions. The upper tension alone has at least 3 or four places that need to be in the correct position.
All of the above has to be done in a certain order also.
Its complicated enough. If someone is going to walk you through this over the phone expect it to be complicated. Even if you had a copy of the manual (which could be a copywrite infringment on newer machines) you can expect it to be difficult.
My advice is to leave it to the professionals to have it done right.
Posted on Jun 20, 2008
RickE1
  • 202 Answers
SOURCE: BSR skips stitches
Hi, I am a Bernina tech and can tell you what the problem is. The problem is that the spring on your BSR is weak. Bernina has an upgrade to adding a heavier spring that solves this problem. The older lighter springs on the BSR is shiny. The newer heavier updated spring is dark. Ask your dealer/tech to change this spring to a new one or give you a newer updated BSR. Also be sure they updated the BSR to the latest firmware.
Rick
Posted on Oct 08, 2009
Testimonial: "Thanks, this was very helpful!"
  • 166 Answers
SOURCE: How do you oil a bernina 1008??
Probably the most important is the inside of the hook ring. Remove the bobbin case and open the hook retainer by pressing the catch on the left-hand-side. The hook can then be removed by just gripping the shaft on which the bobbin was mounted and removing the complete hook. NEVER OIL BEFORE CLEANING. This is the single biggest problem I come across - continually oiling any kind of machine without first removing the old, contaminated lubricant will attract grime. So ... get yourself a few cotton buds and carefully clean around the inside of the hook ring (the circular aperture where the hook was), paying particular attention to the small groove running round the outside. Rotate the handwheel to bring the hook driver round halfway to allow the whole hook ring to be cleaned. Use the opportunity to remove any clogged lint and grime that may have built-up on the underside of the stitch table. WHen you're satisfied it's all clean, then run a very light bead of oil around the groove in the hook ring, turn the hand-wheel fully to bringthe hook driver back to the left-hand-side and oil the other side of the hook ring. Before replacing the hook, take a good look at the groove that runs around the back side of the hook near the edge and thoroughly clean that too, before smearing a drop of oil around that edge with a finger. Replace the hook, making sure its properly seated in the hook ring and click the black plastic cover back into place before replacing the bobbin case. Your machine should now sound a great deal quieter, if you haven't done this for a while !! Good Luck !
Posted on Feb 17, 2010
  • 1116 Answers
SOURCE: My 1008 bernina sounds like it is straining to
Your machine needs to be serviced. Take it to an authorized Bernina service person.
Posted on Feb 20, 2010
RickE1
  • 202 Answers
SOURCE: copy ready diagram of Bernina 1008
Not sure which diagram or scematic you want but feel free to contact me at callnrick@yahoo.com and I will reply with your need.
Posted on Jul 12, 2010
Running slow. Engine going fast, but needle stitching slow.
The motor seems to run faster than the stitching? Can you explain more?
Sep 01, 2013 | Bernina 1008
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
Bernina 1008 troubleshooting
the best thing to do is have the machine serviced at a sewing machine
shop
May 05, 2012 | Bernina 1008
My bobbin case jumps out while I am sewing on my bernina 1008.
it sounds like the bobbin case needs to be replaced, have you cleaned under the needle plate & bobbin area for lint & loose threads
I also would suggest to take the machine to a different sewing machine repair shop.
Mar 05, 2012 | Bernina 1008
Ny bernina 1090 will only sew in reverse
My bernina did this too. Put your finger on the reverse stitch button, and keep it there for a few seconds. You have pressed the reverse stitch button too long, and it has gone into reverse mode. Hope this helps. tich
Oct 09, 2010 | Bernina 1008
I would like to set my bernina 1008 to a freehand setting but d not have the manal i would like ot know what control to have on which setting to make this work
You have to lower the feed dogs and use a darning foot. Use straight stitch setting.
If you cannot lower the feed dogs, this model may use a cover plate.
You can also set the stitch length to zero and tape an index card over the feed dogs with a small opening for the needle.
You will be controlling the stitch length as you move the fabric by hand.
Mar 01, 2010 | Bernina 1008
Feb 17, 2010 | Bernina 1008
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Bernina 1008 - tension problems
Make sure the presser foot bar is UP before you thread the machine, otherwise the thread doesn't connect propertly with the tension discs. Top thread should reel-off in clockwise direction.
Jan 02, 2009 | Bernina 1008
TOP STITCH IS FINE BUT WHEN I TURN FABRIC OVER THE UNDERNEATH LINE OF STITCHING IS LOOSE . WHAT CAN DO TO REMEDY THIS PROB .
Sounds like your upper thread tension is too loose. Try tightening the tension on the top thread, but first, make sure the machine is threaded correctly through the tension disks.
Aug 29, 2008 | Bernina 1008
Sewing Machines Logo
48 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
