Question about LG Dehumidifiers
My LG LD450EAL dehumidifier wont collect any moisture. what gives? ive tried all the troubleshooting in the manual so far with no luck. not sure what else to do now but return it.
  • 121 Answers
SOURCE: LG LD65EL dehumidifier will not collect water
Make sure the filter is clean and also make sure the coils are cleaned. If these are clogged they will restrict airflow which will cause the coils not to remove the humidity from the air. LG recommends that you clean the air filter every 2 weeks. They also include a brush to clean the coils. If this still does not work you will need to contact LG for service or a replacement. They have a 5 year warranty on them so the ones that you guys have should still be under warranty. Make sure that you have your reciept when you contact them to prove that it is still under warranty. Keep me posted. Also please rate my solution when you get a chance. Thanks - Tech101
Posted on Jul 08, 2008
  • 104 Answers
SOURCE: dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
Posted on Oct 04, 2008
SOURCE: LG dehumidifiers
It is defective. The coils are not getting cold enough to condense water in the air. If you have the receipt and the unit is less than 5 years old, give LG a call for warranty repair.
Posted on May 15, 2009
  • 334 Answers
SOURCE: Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
Posted on Jun 20, 2009
  • 156 Answers
SOURCE: lg dehumidifier won't collect water after running for long time
Sounds like it needs to be recharged.
Posted on Jun 28, 2009
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
Jun 02, 2014 | LG Dehumidifiers
How do I hook this up to drain through a hose
The following link is to the Owner's Manual for your unit. Once the link opens, look to the right of the page and you will see Dehumidifiers Manual English. Click on that and the manual will download. Yours is a unique setup, so it's best you see not only the instructions, but also the pictures. Look at the section entitled Disposing of Collected Water, Page 12.
http://www.lg.com/us/appliances/dehumidifiers/LG-LD450EAL.jsp
Hope this helps you. Please let me know. Thanks.
Jul 06, 2011 | LG LHD459EL Dehumidifier
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Jun 25, 2011 | LG LHD45EL Dehumidifier
Does not shut off and overflows
In most cases this problem is caused by the water collection bucket not being installed properly. It may not have been pushed in far enough to allow the full switch to activate when needed. Be sure that each time you remove the bucket to empty it and then reinstall it, that the lift handle of the bucket is all the way in down position and that the bucket is fitting squarely into the holder from top to bottom.
Note: Your specific model has been discontinued by LG. However, some parts are still available if needed.
If you run your dehumidifier constantly and don't want to make a repair to it. You may want to consider using a drain hose, rather than the water collection bucket. This would require a floor drain close to the unit, though.
Hope this helped you to troubleshoot and solve the problem.
Jun 16, 2011 | LG LHD45EL Dehumidifier
My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Feb 25, 2011 | LG Dehumidifiers
Dehumdifier not collecting water.
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
MY DEHUMIDIFIER RUNS BUT NO WATER IS COLLECTED AND I CAN FEEL MOISTURE IN THE AIR IN MY BASEMENT
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 25, 2010 | LG LHD659EBL Dehumidifier
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Aug 15, 2010 | LG Dehumidifiers
Water is not collecting in the bcket. I have had this on and it
whats it set on, check and verify the the compressor running if not wont pull out any humidity
May 10, 2010 | Fedders A7DH45B2A Dehumidifier
Lg LHD30 dehumidifier not producing water; fan and compressor both seem to be working
there may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
Jun 24, 2009 | LG DH30 GoldStar Dehumidifier
Dehumidifiers Logo
372 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
