Question about Jabra BT2050 Bluetooth Headset
How can i pair a bluetooth with my phone i have a jabra bluetooth there is no problsms in bluetooth but no connecting with my phone
    Guru:
  • 395 Answers
Be sure that the headset is in pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
Then find the headset on your phone. If it still not working, please tell the phone model and what is happening when you try to pair.
Posted on Jun 02, 2010
Jabra Cruiser2 Type HFS002. Need help with connecting Jabra to cell phone via bluetooth.
If you have the instruction manual on the jabra, it should tell you how to put the device in pairing mode. Once pairing is turned on you find the device name through the bluetooth settings on your phone. Click pair and they should connect.
Aug 16, 2016 | Cell Phones
How do i pair my jabra easygo to my phone
Hold your blutooth switch on button at few second the light at bluetooth is starts to blink now open bluetooth menu in mobile select pared device and select search new device or go to blutooth menu and select search audio enhancement
Apr 20, 2013 | Jabra EasyGo Bluetooth Headset
Manual for jabra t820
To pair the Jabra with a Verizon Wireless phone, the phone must have Bluetooth. Bluetooth allows a device to communicate and transfer data with another Bluetooth device without having to be physically connected to it. The instructions for connecting the Jabra with the Verizon phone vary slightly depending upon your phone model. Jabra headset instructions don't vary per model.
Jun 19, 2012 | Radio Communications
How do I pair my jabra easygo to my I phone 4s?
Detailed instructions can be found by downloading the user manual from the Jabra support page.
PAIRING IT WITH YOUR PHONE1 Put the headset in pairing mode- When you turn on your Jabra EASYGO for the first time, theheadset will automatically start up in pairing mode, i.e., it isdiscoverable for your phone. When the headset is in pairingmode the Bluetooth status indication on the StatusDisplay isflashing.2 Set your Bluetooth phone to discover the EASYGO- On your iPhone 4s, go to settings>General>Bluetooth and make sure Bluetooth is turned on.3 Your phone will find the Jabra EASYGO- Your phone will find the headset under name Jabra EASYGO.Your phone then asks if you want to pair with the headset.Accept by pressing Yes or OK on the phone. You may beasked to confirm with a passkey or PIN. Then use 0000(4 zeros). Your phone will confirm when pairing is completeand the Bluetooth status indication on the StatusDisplay willshift from flashing light to steady light and the headset voiceguidance will say connected.
Manual pairing modeIf you wish to use the headset with a different phone, or if thepairing process was interrupted, you can manually set the headsetto pairing mode.Make sure the headset is on. Press and hold the answer/end buttonfor approximately 5 seconds until the Bluetooth icon turns froma steady light to a flashing light. Then repeat steps 2 and 3 in theabove pairing guide.Connecting with your phonePairing is only needed the first time a headset and phone areused together. When the headset and phone have been pairedonce, they will automatically connect when the headset is on andBluetooth is activated on the phone. The headset can be usedwhen it is connected to the phone. If the devices are paired, butdo not immediately connect, tap the answer/end button. Whenyour headset is connected the Bluetooth connection icon in theSTATUSDISPLAY WILL BE CONSTANT ON FOR 3 SECONDS andthe headset voice guidance will say connected.
Feb 19, 2012 | iPhone Apps
How to connect to phone
Depending on the phone, you need to enable bluetooth. then according to the directions on the Jabra, set it to "pairing" mode. Use the phone in the bluetooth menu to "find devices". Once it finds the Jabra you should need to enter a code to "pair" it, should be 0000 ( all zero's). Once paired, it should connect each time you turn the headset on.
Dec 31, 2010 | Jabra SP5050 Bluetooth Headset
Cant connect my Jabra BCE OTE4 with my LG 8300 cell phone...help
default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
Aug 21, 2010 | Jabra Bluetooth Headset with Adjustable...
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Mar 06, 2008 | Jabra BT350 Wireless Headset
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 23, 2007 | Radio Communications
Jabra connection
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 02, 2007 | Jabra BT150 Wireless Headset
Jabra BT2050 Bluetooth Headset  Logo
229 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
