Question about Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Dishwasher
Bosch SHX33 drain pump continues to run
About two year old d/w has progressively kept running longer and longer after draining. Now it just tries to drain full-time. No water enters after reset and starting new wash cycle. All filters clear. Water runs very quickly through entire drain system. Drain pump would continue to run for hours if left alone.
  • kenlenard Nov 28, 2008
    Same problem. Ours ran for a bout 6 hours while we were out. Came back & pump was running, dished were clean and no water was in the d/w. I tried to cancel but it will not work. I turned off the breaker to see if it will reset.
  • msk9 Apr 23, 2009
    We run dishwasher when we go to bed. Got up next morning and unit was humming. Opened door to find it full of water. Played around and got it to drain. Now the drain runs all the time I have added water and it will pump it out but still runs even with the door open. Have reset the circuit breaker still the same thing.
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
SOURCE: My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Posted on Mar 20, 2010
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
Bosch 24367
Drain hose or pump is blocked. Hose could be kinked.
Can you hear the pump running when it is trying to empty?
Nov 21, 2017 | Washing Machines
Bosch WFLI2440GB/5 Washing Machine drain pump running continuously
Bosch WFLI2440GB/5 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 08, 2011 | Washing Machines
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch SHX46A02UC-21
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Open Questions:
See all Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Questions
Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Dishwasher Logo
212 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
