Question about Nokia 6630 Handheld
My nokia 6630 is ori from the japan..but when im use a sim from malaysia it cant detect the sim card.imalready try to format but some shop tell me they try to format but same problem not gone
    New Friend:
  • 64 Answers
You have to unlock the unit,
because cellphone from other country is lock on its
network provider..
unlock it using JAF software..
Posted on Jun 10, 2010
Want to formate phone memory
go to phone file manager and then go to the memory card drive and select the partiton u want to formate and then go to option then select formate.........
Aug 22, 2009 | Nokia 6630 Cellular Phone
Nokia 6630 Restart and Hanging
TAKE OFF YOUR MEMORY CARD N RESET YOUR PHONES, THAN PUT YOUR CARD TO THE COMPUTER N FORMAT THE MEMORY CARD.
Dec 27, 2008 | Nokia 6630 Cellular Phone
How to unlock a Nokia 6630?
tell me ur imei of u phone i will tell the lock code
Dec 11, 2008 | Nokia 6630 Handheld
Isert sim card
Hi nay,
there's simple solution, first, take out the sim card and battery, then put it back again, switch the phone on, the phone will ask you "do you want to stay in offline mode?", click no. then you'll have your network again, if the message don't came out, then there's some probabilities.
1. sim card connector.. see those yellow (look like gold coloured mostly) pins that usually beneath your sim card if you insert it? probably when it's fall, it's bent, so your sim card mght not be well attached to your sim card connector. raise the feet (pins) of the sim card connector, so it became higher. so that you make sure your sim card is touched by all the pins. replace the battery and sim card, switch on again. mostly will help. but if not, try below steps
2. probably There's something cracked or broken from the body of your phone (inside), so your phone become loosened up - mainly at the screws(your sim card become not well-attached), so what you have to do, is take a screwdriver for nokia, and strengthened the screws. If it can't, try borrow 6630 of your friend, try your board (machine board) to your friend's 6630 body. If it doesn't work, then it means something on your machine board (component) is broken, not because it's just loose.
If you doesn't have friend that use 6630 too, or you feel it's hard to open your phone, look closely if there's any major crack on the body of your phone, if it does. go to any mobile phone sparepart or accesories shop, buy a new body and ask them to cahnge it (actually piece of cake, try it..) well if it doesnt work, there's nothing to lose, because anyway if you want your phone fixed, you're not gonna use it with a cracked body. (differ body and casing)
3. If you're sure none of above helpful, then it means , some component is broken. Usually it comes to SIM card connector feet (that is attached to your machine board) or the sim card IC, some small possibility is you UEM IC is broken, but in this case, i suppose not.
your sim card connector feet (attached to machine board) might be not well attached (lifted up) caused by the crash when you fell your phone down. so it just need to be reattached by solder. you need a technician for these. if it doesn't help, your sim card IC need to be replaced by a new one (this IC SIM CARD is make of glass, so it's so fragile), leave it to the technician, this shouldn't cost more than 10-20 usd i promise ^^
Good luck with raising the pin (the one that touch your sim card-don't be confused) of your sim card connector. Mostly will help ^^
Nov 15, 2008 | Nokia 6630 Handheld
Nokia 6630 sim problem
first clean u r sim card and then sim base and then format u r phone by typing *#7370# it will work
Nov 06, 2008 | Nokia 6630 Handheld
Chnage of SIM CARD
The phone is locked to the network in phillipines.You will have to get the phone unlocked by any store who perform a software reflash
Jul 22, 2008 | Nokia 6630 Handheld
Nokia phone 6630 cannot install files
hi,
you can try to unlock the phone by taking to any mobile service showroom..it doesnt cost much to unlock your mobile from a particular network after which it is at your convenience to use any network as you prefer!..thank you!!..
Jul 01, 2008 | Nokia 6630 Cellular Phone
Nokia 6630 Sim Card locked......Kindly help unlock.....
if u put the lock code in wrong about 5 times it should ask u for puk code you can get this code from your service provider ring them up they ll give u the code over the phone this ll override the security code and then reset it to 00000 so get the code wrong a few times then call the service provider when ur phone asks for the puk codeits 11 digit and it from ur service provider
May 10, 2008 | Nokia 6630 Handheld
i seen ur problum, if u want to unlock ur 6630 then u must have a ufs box thats cost near about 5000 Rs/- only other wise u may go to any nearst service senterok
that is only solution.
in unloking ur data will not remove. that will remain as it is ok
then dont wory go to any service center an tell them to un loke ur nokia 6630
bye
Feb 19, 2008 | Lands Phones
Nokia 6630 Handheld Logo
48 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
