Had to get computer fixed cannot reinstall my printer because i cannot find my cd-rom to install it on my computer is there any other way to do this
  • 385 Answers
please provide me with the model number and brand of printer and I can help you.
Thanks,
Lolita
Posted on Apr 08, 2008
SOURCE:
My CD rom will not download to my computer. Originally my computer would not communicate with the printer. So I removed the program and tried to reinstall it with the CD rom and it will not load. How do I...
Try to use the Lexmark P6250 driver from the Lexmark website at http://bit.ly/9GDVnj. Select your operating system (if needed) by clicking on "change OS". (see image below)
Then click on "FILTER". (see image below)
Click on the driver under "Recommended Downloads". Download and install the file. Follow the instructions in the software.
Hope you'll be able to successfully reinstall the printer software using this downloaded driver. If problem continues, please contact Lexmark technical support to further investigate this problem. Thanks.
Nov 10, 2010 | Lexmark P6250 All-In-One InkJet Photo...
New computer. need to reinstall printer
Put the cd with the drivers to the printer in the CD rom and plug the printer in USB/LP1.. when the system finds the printer you shoul point the installation to the CD so that the printer finds the right driver.
Aug 25, 2010 | HP Office Equipment & Supplies
I have a brand new HP C309a PhotoSmart Premium printer. I cannot install the CD -Rom, it kept failing in the middle of installation, I did turn off antivirus and other services before installing the CD-Rom...
herer what u hv to do is tht, you hv to reinstall the operating system of ur computer, cuz this is the same prob tht i was facing 1 year ago
u want ge any more fix relating to this prob
orrrrrrrrrrrrrrrrrr you must hv windows 7 cuz in windows 7 you dont hv to install any software for printer,webcam, sound, bluetoothg etcccccccccccccc
Mar 14, 2010 | HP Photosmart Premium C309A All-In-One...
Cd rom
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
Mar 10, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
My scanner is not working. Can't open HP director on my laptop. I tried to reinstall CD that came with it, but " more recent version installed" Printer and copier work fine.
Here are some diagnostics.
1. Go to control Panel and then to scanners & camera.
2. look for your scanner there.
3. if you find your scanner there try to scan from the wizard and you will be able to scan you docs.
To Reinstall the Hp Director....
1. first uninstall the HP director software using the removal utility located in your cd...
The uninstaller on the Internet is newer and works better than the one on the CD-ROM. Use this method only if the Internet version is not available. Follow the steps below to use the CD-ROM version only if you cannot get the regular uninstall to work correctly and cannot access the Internet:
  1. Leave the USB cable disconnected from the all-in-one.
  2. Insert the all-in-one CD-ROM into the computer. Cancel or close any installation windows that appear.
  3. Right-click the Start button, and then click Explore . This will open Windows Explorer.
  4. In the pane on the left, locate the CD-ROM drive letter that contains the all-in-one CD-ROM.
  5. There are two different versions of the software for some of these models. Use the file path that pertains to your version of the all-in-one software.
    • Early versions of the HP Officejet 6100 and PSC 2100 and 2200 series: Double-click the file hposcr01.exe , located in the Drivers\Uninst\language (ENU for English, ESN for Spanish, FRA for French, or PTB for Portuguese) folder of the CD-ROM.
    • The newer software version: Double-click the file Cleanall.bat , which is located in the Util\CCC\Cleanup folder of the CD-ROM.
    ONCE THE SOFTWARE IS COMPLETELY REMOVED.RESTART THE PC AND TRY TO INSTALL THE HP DIRECTOR SOFTWARE FROM THE CD.
Let me know for any further help....
http://www.ikarmatech.com
Sep 08, 2009 | HP PSC 2410 All-In-One InkJet Printer
My brother 2070W acts like it receives the data, but it never prints
When reconnecting the USB cable to the computer or laptop the cable must
be reconnected to the same USB port it was previously connected to. Otherwise, Windows will install another copy of the printer
driver and the printer will no longer print. Most computers have two or
more USB ports. To prevent this problem from occurring we would
recommend labeling the end of the USB cable to indicate which USB port
the cable must be reconnected to.
To resume printing the printer driver should be removed then
reinstalled.
In Windows 2000 open Start, Settings and Printers. In Windows XP open
Printers and Faxes. Double click one of the Brother printer icons to
open the print queue. If print jobs are listed click Printer and Cancel
All Documents. Repeat this process for all copies of the Brother printer
driver.
Delete all copies of the Brother printer driver by selecting the printer
and clicking File then Delete.
Once all the copies of the Brother printer driver have been deleted
click File and Server Properties. Click the Drivers tab. Select the
Brother printer from the list and click the Remove button. Click Close.
The printer driver can be reinstalled using the Brother CD-ROM or
downloaded from the Brother Solutions web site. Check the CD-ROM to
verify it lists the operating system installed on your computer. If your
operatingsystem is listed insert the CD-ROM and install the printer driver.Before installing the printer driver disconnect the USB
cable from the back of the printer. Do not reconnect the USB cable to
the printer until the installation prompts you.
If the CD-ROM does not list the operating system installed on your
computer the CD-ROM should not be used to reinstall the printer driver.
The newest version of the printer driver is available for free download
from the web site below.
http://solutions.brother.com/model_list/mono_laser_us.html
How to install the downloaded driver:
1. Download and save the Windows 2000/XP driver to your desktop.
2. Once downloading is complete, Double-click the file to open the
WinZip Self-Extractor. In the Unzip To folder section, change the path
to c:ro, click Unzip and click OK. Click Close to close the WinZip
screen.
3. Open Printers or Printers and Faxes.
4. Click Add Printer or Add A Printer.
5. Click Next on the first screen. Select Local printer. Remove the
check from Automatically detect and install my Plug and Play printer and
click on Next.
6. Select a USB port and click on Next.
7. Click the Have Disk button and type the directory c:ro.
8. Click on OK.
9. Select the model and click on Next.
10. Select Yes to use the printer was the default printer then click
Next.
11. Select Do not share this printer or Share as and click on Next.
12. Click on Yes or No to print a test page.
13. Click on Finish to complete the installation.
Do give my solution the highest rating if it solves your problem. Thank you for using fixya.
Aug 04, 2009 | Brother Office Equipment & Supplies
I have a eee asus laptop. I cannot startup the window at all. The pc show this message; "Windows could not start because the following file is missing or corrupt C:windowssystem32configsystem " how can i...
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Jul 13, 2009 | ASUS Eee 4G Notebook
Lost installation disk for canon pixma iP 1500 inkjet printer
how do i install my printer onto my new computer if i lost the installation disk or cd rom?
I've lost the installation disk for mu Canon PIXMA iP4000. How can I download for free to reinstall? Thanks.....George
Jun 03, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
INSTALLATION
techspot has a driver
try that one
Dec 14, 2007 | Computers & Internet
Open Questions:
AOL MAil PHoNe $%{1^855^536^5666}#[email protected] NuMbER UTAH This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 21, 2019 | AOL Computers & Internet
AOL MAil CuStOMeR {1-855*536*5666}#[email protected] NuMbER WYOMING This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Computers & Internet Logo
19 people viewed this question
Ekse
Marvin
Marvin
