Question about ASUS Eee PC 1000H Laptop
Missing ntldr in my eee pc 1000h it doesnt have cd rom so what i do
  • Adnan Bhatti
    Adnan Bhatti Jun 01, 2010
    I have a complete method to install Windows using USB flash drive.
  • john_nepales Jun 01, 2010
    ok tell me how to make usb flash drive as bootable usb flash drive
    Master:
  • 644 Answers
You will have to use an external CD drive or make a bootable USB drive and repair the OS from that.
Posted on Jun 01, 2010
  • 108 Answers
You search for windows 2003 Remote Installation Server around you if available.. take the help
NTLDR is missing
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Nov 12, 2010 | ASUS Eee PC 4GB Notebook
Bluetooth doesnt work- says no device. FN keys doesnt work on the screen, only turns on and off wireless.
You have to reinstall the ASUS Eee bluetooth driver. If you've your CD driver, insert it in and look for Bluetooth. Otherwise click on this Link to download it;
http://www.notebook-driver.com/asus/asus-eee-pc-1000h-netbook-windows-xp-driver-and-utilities/
Good Luck!
Jun 24, 2010 | ASUS Eee PC 1000H Netbook
It might be caused by a virus or a sign of failing hard drive. the first step would be to take out the HD and check it with another pc to see if it is ok.OBS make sure you have a functional anti malware and anti virus installed, updated and running on the second pc!!
Then if the HD and its files are accessable, back up the files you need thenrecovery format the HD. put it back into your eeepc and by means of an external CD/DVD install the windows. If you dont have the recovery cd then try to find an OEM copy of windows on the internet that way you can use your OEM windos key under your eeepc.
I will be hapy to answer your questions!
Good luck !
Jun 01, 2010 | Computers & Internet
My eeepc says NTLDR is missing and I have tried to replace the software using an external drive but it wont start
If you get the "NTLDR is Missing" error, follow these instructions:
1. Load Windows XP CD into CD drive.
2. Make sure BIOS is set to boot to CD drive.
3. Boot the computer from CD.
4. At menu, press "R" to load Recovery Console.
5. Select the installation to be fixed.
*The following instructions assume CD-ROM is labeled as drive D and the hard drive partition the windows installation is on is labeled as drive C. Replace the letters accordingly.
6. Type "COPY D:\i386\ntldr C:\" and press ENTER.
7. Type "COPY D:\i386\ntdetect.com C:\" and press ENTER.
8. Remove CD and type "EXIT" and press ENTER (to reboot your computer).
Oct 21, 2009 | ASUS Eee PC 1000H Laptop
\$WIN_NT$.~BT\biosinfo.inf could not be loaded
Should be here: C:\WINDOWS\inf\biosinfo.inf
Sep 01, 2009 | ASUS Eee PC 1000H Laptop
RE:NTLDR is missing(solution 1&2)
nt loader is missing well this is a file required to load windows,if you have a external cd rom you may boot the windows install cd,if the pc in question has a internal drive you can use this to repair windows,now if you have to install anything to this computer you will need this cd drive.
Good luckc
Aug 29, 2009 | ASUS Eee PC 1000H Laptop
NTLDR is missing..how can i log-in to the windows?huhu..pls help
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
NTLDR missing issue
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jul 29, 2009 | ASUS Eee PC 1000H Laptop
Eee PC system recovery...NOT
First your pc in cdrom Or DVD rom.You go to BIOS select boot option select first boot divice on cdRom.After click on f10 save and exit click on ok. after enter the dvd on cd rom.
Jul 07, 2009 | ASUS Eee PC 1000H Laptop
I just bought this eee pc and it not set up like my friend and i like to set it up with win xp
well, you will need a windows XP cd and a valid product code. you will also need either a USB cd rom, or one of those ide to usb kits sold on ebay (make sure it comes with the molex power adapter), and a standard IDE cdrom drive. connect the usb drive to the eee pc and insert the xp disc, restart and boot to the xp disc and install xp that way.
Jun 05, 2009 | ASUS Eee PC 1000H Laptop
ASUS Eee PC 1000H Laptop Logo
303 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
