Question about LG 24 in. LDS 5811 Built-in Dishwasher
It doesn't work--there is an error message OE or it just beeps & shuts off w/o cleaning the dishes.
I have had this dishwasher since 3-25-08. It has been repaired 1x, played with daily to get it to drain--and the service center is unresponsive. I now just want this pos gone. I have had to shut it off and then turn it back on and just hit rinse to get it to drain. Why?
  • civmel Oct 15, 2008
    my dishwasher beeps oe and will not drain, turned off and try to rinse but flashes oe again.
  • Richard Lew May 11, 2010
    Describe in detail what is it doing.  Any error messages being displayed??
If you can get a repair-man to come out at least once or twice more and the problems aren't solved, you definately need to get on LG's case and have them replace it. My LG dishwasher was repaired about seven times before LG would do anything. I bought mine from an appliance dealer and they even had to fight just to get a response from LG. When LG finally agreed to replace the dishwasher (about a year after all the troubles began) my retailer allowed me to choose another brand of washer. I'd recomend a KitchenAid or Whirlpool, they have performed well in my home in the past and currently as well. The problem with your dishwasher right now is likely the motor. It seems to be the big thing that goes on all theses dishwashers. For me the motor was the last part to fail, it was having a hard time draining, the soap was not being disolved, and the dishes were always coming out dirty. My repairman told me that the LG products have been **** and he wouldn't recomend them. He told me this as long as I made sure his boss didn't find out. Good-luck with your fight against LG Customer Service, I hope you manage to resolve this faster than I did.
Posted on Apr 27, 2008
SOURCE:
Plugged drainage on dishwasher
clean your filters on the bottom tray. the pump impeller might be jammed or the drain hose might be kinked or be blocked hope this helps
Jan 05, 2014 | LG LDF6920WW - Dishwasher with...
My dish washer makes a beeping sound when switched on, and doesn't work.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
LG 1419LF My dishwasher stops during its cycle, it shows an error message: OE, there is 2 inches of water at the bottom of machine...Please help...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | LG Dishwashers
LG WASHER STOPS BEFORE THE END OF THE CYCLE..OE IS THE ERROR MESSAGE ON THE SCEEN
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Feb 04, 2011 | Dishwashers
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher ld14aw2 error
Did the owner of the LG LD-14aw2 that was giving the OE error get the problem resolved?
With an OE (Drain Error), it means that the dishwasher is not fully drained out in spite of 5 min. drain operation. First step of the trace the entire path of the drain hose to the sink drain. Be certain that ther is no blockage in any of it.
It that does not resolve the problem, remove the lower spray arm and the screws that hold the sump area down. Open up the area and inspect everywhere for debris that could be blocking the drain area.
Next step would be to replace the drain motor.
With the LG dishwasher that is giving an IE error: Double check that the water valve supplying the dishwasher is fully open. Next, with the water turned off, open the connection between the inlet pipe (hot water) and the dishwasher inlet valve. Clean the screen of all debris/minerals that often build up there.
If problems continue, check and replace the inlet valve.
Thanks for reporting back what you have found. Good Luck!
Dec 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
142 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
