Question about InFocus LP 130 Multimedia Projector
Hi There... I have problem with my Infocus LP 130 The power is still ON, fan at the back is still working caused I can feel the air flow, but no light coming out from the lens. Can you please advise, what could be the problem? is that the bulb?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Theres another fan next to the engine. all fans must work for the lamp to light. the colorwheel must be turning freely for the lamp to light. you can also take the top cover off and then slide the lamp out and then back in while watching to see if the connection on the lamp is pushing the female part on the lamp housing back instead of going into it. if it is, hold the female part in place with a driver or something while pushing the lamp into it.
Posted on Jun 11, 2010
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
LP-130. lamp won't come on. How do I know if
check the lamp. look on the inside for bulges, black spots, flaking or fogging. replace if you have any of those. if the lamp is ok, check the colorwheel. if it doesn't spin, that's your problem. if it does, it's the ballast. the bad news: infocus doesn't have parts for this model. sorry.
Jan 20, 2010 | InFocus Office Equipment & Supplies
Infocus lp 130 projector has developed a dark spot/line the goes from the bottom center of the screen to about halfway up. This was never there prior. Anyway know what this might be? cleaned the lens...
the light tunnel has collapsed and needs to be replaced. unfortunately, infocus no longer makes or has parts for this model. you could try and find one on ebay. usually the power supply goes on those, so if someone has one with that problem you could get it and swap out the parts. good luck!
Dec 08, 2009 | InFocus LP 130 Multimedia Projector
What is usually the cause when a projector overheat?
restricted air flow. either one of the fans are not working, the vent is blocked, or the projector is filled with dust. so, check the fans (if they are slow, replace them), make sure nothing is close to the back or sides, and blow out the dust with canned air. if it has overheated a number of times, you may need to replace the thermosensor.
Oct 21, 2009 | InFocus X6 DLP Projector
In-Focus LP-130 and it turns on but the lamp wont fire up, it sounds like the cooling fan goes on and then stops, its a brand new bulb also.. some one said its daughter board that controls the cooling lamp...
the ballast is bad. the fan turns on for the colorwheel, but when the lamp doesn't strike, the fan and colorwheel turn off until it tries again. unfortunately, there are no replacement parts for the lp130.
Jul 17, 2009 | InFocus Office Equipment & Supplies
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
LP 130 PROJECTOR SCREEN IS GREEN WHEN I HOOK UP DVD WITH COMPONE
the cable might be the problem. swap out with another cable. other than that, make sure that the correct input is selected and the resolution matches.
Mar 11, 2009 | InFocus LP 130 Multimedia Projector
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Jun 16, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP 130 Multimedia Projector Logo
282 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
