Question about Microsoft Xbox 360 Console
My xbox says reading disc, clicks twice then says open tray. it looked like it would try to run the game a couple times but would then follow with open tray
  • 35 Answers
SOURCE: Xbox 360 wont read disc
Though i fixed the Disc Read Error myself within an hour but please test the below method at your OWN Risk. Please also note that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourself within an hour. It also provides the money back guarantee in case you are not satisfied. As i fixed my Xbox myself so i thought to share it with you guys.
Posted on Mar 07, 2009
  • 46 Answers
SOURCE: wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
Posted on May 12, 2009
  • 51 Answers
SOURCE: games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Posted on Jun 01, 2009
SOURCE: xbox 360 wont recognize game discs
your lazer has packed in my sugestion is to buy a new one. i had the same problem
Posted on Jun 24, 2009
jennifer0607
  • 50 Answers
SOURCE: Xbox wont read discs, unless i hit it....
open tray right??
-check the time and date settings,even the time zone as well
-try to load the disc without the hard drive or memory unit
-look for corrupted files at the memory, delete it
-do the system maintainance,
system settings>>memory>>hardrive, press y for device options, press this in sequence x, x, Lb, Rb, x,x>>yes
Posted on Jun 27, 2009
My xbox 360, has a problem i put in a new clean disk(game) into the xbox . it is a xbox 360 game and every time i put in a new clean disk the xbox says (open tray)
The XBox 360 is a wonderful video game console, however, with heavy usage, the laser (and/or other components in the drive) will eventually burn out.
The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the games will stop reading altogether and you will get an "OPEN TRAY" message when you put a disc in and close the tray. What this means is that the XBox 360 thinks that there is no disc in the system.
If you click into the following U.S. based website, you can find more information about this issue, the parts to fix it yourself and you can also send your XBox 360 to them to have it repaired:
http://store.richspsxparts.com/howtofixxb36.html
Jun 21, 2011 | Microsoft Xbox 360 Console
Tip
XBOX 360 WILL NOT READ DISC SAYS OPEN TRAY
eject the game from the cd console if in the drive make sure your xbox is on warm it up take the disc if it is dirty run under warm water all over the silver side of the disc till dirt and debris gets completely removed after still holding the disc turn off the water and use scott SCOTT brand toilet paper the straight kind and use about four sheets to dry the disc or use a blow dryer, not preffered prefreably scot toilet paper after the disc is dry and warm very dry take your clean index finger and remove the rest of the debris off the disc and when the xbox says open tray let it say close tray close it see if it says read the disc if it says read the disc then it is not your laser or the laser needs to be blowed off with an air gun or compressed air. Get it to say close tray and itll close it self, wait ten seconds turn off the xbox turn it back on and go to my xbox mash play wait for it to read the disc. THE DISC WILL NOT WORK IF IT IS DIRTY I reccomend running it under warm water (let dry on both sides while still holding it properly) use a non scratch cloth to clean the disc preferablly scott toilet paper the smooth kind, after it is dry put the disc in the console if youve tried the disc try a brand new disc it might definately work after it says read if it says play the game then its the disc. If nothing happens like it dont say reading disc then your laser is cracked corrupted, or it has debris on it or is wett. Dont let your laser head get wet because i told you to run it under water make sure the disc is dry and completly free of scratches and smudges. WASH THE DISC WITHOUT SCRATCHING IT. Dont put a wet disc in your x box. Mash the hard drive button down and release mash reset to recycle the xbox green lights. Remove all the cords fromt the xbox wait two weeks or shorter, I waited a month or more before i played my game and it worked after I cleaned it twice one time and a month later i cleaned it without soap and used luke warm water.Remember Open tray, press buttom close tray closing automatically should say read reading reading disc then play if does not read the disc then its your laser. If its your laser and you are sure its your laser do not remove the hardrive or any screws they can tell youve botherd it because that will void your warranty. go to www.xbox.com/support its a pdf file print shipping label follow the steps to repair.
on Jun 13, 2010 | Video Game Consoles & Games
My xbox 360 elite keeps on saying open tray even though i have a game in i would open it than it would read for about 2 seconds than say open tray again and i dont want to take it apart to void my warranty
The warranty on the XBox 360 is ONE YEAR. If you have had it for more than a year, there is no more warranty to be void. You can open it.
The XBox 360 is a wonderful video game console, however, with heavy usage, the laser (and/or other components in the drive) will eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the games will stop reading altogether and you will get an "OPEN TRAY" message when you put a disc in and close the tray. What this means is that the XBox 360 thinks that there is no disc in the system.
You can click into the following website for more information, as well as parts to fix this issue:
Jun 20, 2011 | Microsoft Xbox 360 Console
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
My xbox keeps saying open tray I brought it to a guy twice and no fix everytime I put a game or movie in it it reads and says open tray
Reasons
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
May 08, 2010 | Microsoft Xbox 360 Console
Same problem: 2 clicks when I put disc in, then 'open tray' shows
OK, this solution isn't very professional. I have the same problem all the time. The problem is a result of the xbox 360 dvd drive wearing out. It wears out faster when the xbox is vertical. Make sure you have the disc out of the xbox if you do this, this is the method I found so I don't need to spend 100 dollars for a new drive. In anger, I banged the xbox up and down a couple of times, then put the game back in, and it was fixed. This may require multiple tries to do, but it SHOULD fix it. A good thing is it doesn't violate the warranty. I have done this quite a few times and it worked. Good luck.
Sep 25, 2009 | Microsoft Xbox 360 Console
open tray right??
Jun 27, 2009 | Microsoft Xbox 360 Console
My xbox doesn't always read games and movies and is getting very frustrating please help
Well if the discs have either no scratches or light scratches I would guess you need to run a laser lens cleaning disc through it. I try to run one every month because it is natural for dust to gather and collect on the laser lens over time.
Apr 30, 2009 | Video Game Consoles & Games
Laser is not reading disc says "open tray" after 2 sec. xbox 360
my xbox 360 elite has 2 red lights, which im led to believe is over heating, but it had only run for 15 seconds so cant of overheated so whats the problem? regards paul.
Jan 16, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
657 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
