Question about Karcher Garden
I have a Model G2500VH with a Honda GCV160 5.5 motor. Is there a rebuild kit for the pump?
4 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: karcher 2400 pressure washer with
The pump is correctly oiled and lined up on the camshaft, correct?
Posted on Jul 20, 2008
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
SOURCE: My Honda GCV160 Pressure washer runs great, but
Take hose and gun off pump.
Start engine.
See if pressure comes out of pump.
Next, remove water hose and look at filter washer.
Clean or replace filter washer.
Turn on water and it should come out of pump on other side.
These steps will tell you if problem is water supply or pump.
Sometimes the problems happen because the gun lever is bad.
Hook up hose but not the gun
See if pressure comes out hous.
These steps will tell you if problem is gun or hose.
Posted on Oct 25, 2010
How do I replace washer pump in 1985 Chevrolet, don't know where the wires are connected
I think the pump is built into the washer motor on your model, and you can buy a rebuild kit with instructions.
Jan 19, 2015 | Cars & Trucks
Need a rebuild kit for pump not motor
A O Smith does not make a Pump,
they make motors, so...
what pump do you have, so pump rebuild kit can be recommended?
Apr 13, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
G2500vh milky oil
Water has gotten into the pump via a blown seal. Your pump is probably not good anymore
Nov 12, 2013 | Karcher Garden
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
1996 honda magna vf750 fuel pump, need rebuild kit or a new rubber diaphram has pin hole leak.
Your model 95 or 96 VF750 Magna does not have a fuel pump. I believe the part you are talking about is the vacuum fuel petcock assembly. The part is only sold from Honda as an assembly.The part number is # 16970-MZ5-003 and runs about $120.
Apr 10, 2011 | 1995 Honda VF 750 C Magna
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
I need a rebilding kit for a.osmith motor mod c48k2pa105 1 hp 115/230
There are no rebuilding kits per say. Rebuilding a motor entails stripping it down and replacing what's bad. whole inside should be cleaned of debris, dust, rust etc. Almost always bearing are replaced. Armature, rotor and stator are cleaned, motor windings tested, start/run caps tested and replaced as necessary. Thermal overload, contactor, relay, centrifugal switch, etc, tested and replaced if needed. You can order bearings and capacitors from several places online, other parts can be harder to find. I local pump repair shop may sell you parts as well.
Jul 14, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
Can't find a carb rebuild kit for my 1983 Honda VT500FT Ascot
Bike Bandit has everything you need to rebuild the carburetor on your 1983 Honda VT500FT V-Twin Ascot, click on the link below to view
http://www.bikebandit.com/houseofmotorcycles/1983-honda-motorcycle-vt500c-shadow/o/m9690
Apr 18, 2010 | 1983 Honda vt 500 ft ascot
Rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Crosman model 200 rebuild kit for the pump
You can order a crosman rebuild kit from:
Bryan and Associates
Anderson, SC
1-864-261-6810
Feb 08, 2009 | Crosman ® Quest cal. Air Rifle with 4x32...
Garden Logo
252 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
