Question about GE Spacemaker JVM1640SJ Microwave Oven
Control locked i have the same problem with my microwave. it says control locked and none of the key pad keys work. how can i fix this?
  • 1 more comment
  • mayayai Sep 08, 2008
    GE jes738wj control pad does not work
  • tiyawilliams Mar 21, 2009
    Our GE Spacemaker Microwave worked fine yesterday and today the control pad does not work. Tried plugging/unpluggin and the Clear/Off button it says in the book, but that does not work. Microwave is less than a year old.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and full model number.
  • GE Master
  • 9,098 Answers
If yours is a GE JVM1640 or similar GE model, here's what the owner's manual says:
To lock or unlock the
controls, press and hold
CLEAR/OFF for about
three seconds. When the
control panel is locked,
an “L” will be displayed
to the extreme right.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
How to fix key pad on ge convection oven jvm1790bk. Pad stopped working
The control panel is actually 2 different parts and either could be bad. Do you have the display still lighting up or is it completely dead? If it is out it could the main smart board. If it still lights but no buttons work then it could still be the smart board or just the key pads which are a separate part. Neither part can be fixed just replaced.
Feb 26, 2015 | GE JVM1790 Convection / Microwave Oven
I was cleaning fingerprints off the key pad and maybe hit the child lock none of the buttons work at all...i tried the 3 seconds for the stop cancel and that didnt work
There are different ways to lock the keys on different microwaves. I cannot find a manual for this unit, so the only other thing I can think for you to do is to unplug the microwave overnight (if you don't need it right away) and see if it will reset when you plug it back in. I'm so sorry I cannot find a better answer
Joe
Sep 07, 2011 | Westinghouse WST3501 Microwave Oven
None of the keys work
the touch pad has a ribbon cable that connects to the control board poosible that the touch pad has failed or the control board itself.... most of the time the touch pad fixxes the problem... if you have power and all still try ordering the touch pad for the unit...
good luck to you
Jan 09, 2011 | Microwave Ovens
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
Jan 01, 2009 | Microwave Ovens
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Child lock
unplug it, then plug it back in! quick fix!
Mar 22, 2008 | Welbilt MR90T Microwave Oven
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Goldstar microwave
The control panel has the child lock turned on.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't work, try holding down the "0" pad for about 5 seconds.
Different models use different keys, so try "Stop/Clear" and other keys.
If all that fails, contact LG customer support at 1-800-243-0000 or http://us.lgservice.com
Dec 22, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
276 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
