Syntax 635MP no PCI video?
Syntax 635MP (onboard CPU) @ 800mhz. I cannot find any way to initialize a PCI graphics card.
Any ideas? PCI is default setting in BIOS- but changed/changed back just to see if that did anything. No jumpers for it. Simply cannot move away from the onboard AGP- no how, no way (that I can find). Plug in a known-working card- got a blank/black screen. Slot works as I tried a USB card in the same slot. Also, no contacting the co. about it- their motherboard section has vanished- as far as Google is concerned...old page showing board is here:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=146907&csid=ITD&body=MAIN#productresources
  • Tracy Jun 01, 2010
    There is no option to disable the onboard on this particular motherboard- that's the issue. I've built many towers- just so happens this little all-in-one board has a limited BIOS. All you get is a choice- which to initiate first, PCI or AGP...that's it.
    If I plug in the PCI card & connect to it- nothing- blank & black. If I then swap the cable over to the onboard/AGP- it pops right up. I still have the manual for the board & all it says is a PCI video card can be installed- nothing more.
  • 11,800 Answers
You don't move it away, you install the new video card in the pc, you connect the monitor to it, you start the pc and go in the BIOS and in there you disable the onboard video. After that it will work just fine.
Posted on Jun 01, 2010
I actually have the 512mb graphics card but my question is how do i install graphics drivers when the installation disc wont even do a complete install?
unplug power cod, open computer Cabinet panel, remove cmos for 2 min and reinsert cmos,
wipe graphics card socket, reinsert graphics card, TURN on computer, press f2 to load default setting
you do not need to disable onboard graphics. in bios, some bios default configure your graphics card to primary
hope will help you
Apr 29, 2014 | ASUS Video Card ATI RADEON HD 5450, (1 GB)...
NO ONBOARD VIDEO
Hello here is the ASUS homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N73-AM&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Your pci-e graphic card is failing or has a defect.
The problem could also be the power supply, not giveing enough power.
When you add a pci-e graphic card on the mainboard, the onboard graphic should deactivate itselves.
Try to remove the pci-e graphic card, and use the onboard graphic.
If still no picture, change the power supply.
Its not possible to change settings in the bios blindfolded.
You can reset the bios by removeing the cmos battery.
But ofcouse it could also be the mainboard itselves failing.
This is rarely happening, so i hope its just the power supply.
Try also to look for visual defects on the mainboard, especially the condensators on the mainboard.
Good luck
Apr 14, 2013 | Computers & Internet
I want to install my palit geforce 210 1gb ddr3 on my desktop with win7 & 3gb ram, model of cpu is aspireM5600. The problem is, when I installed the vdeo card driver and it requires to restart the
Using onboard graphics enter into the BIOS and set the setting to display to PCI-Express first then onboard if noexist PCI-E graphics.
Save and exit.
This will allow you to install your new graphics card to your monitor.
Take care!
damnor01
Sep 11, 2012 | Palit Microsystems Palit nVidia GeForce...
Hello, I just bought my ECS Geforce GT430 (Model: NGT430C-1GQR-F). I put it on the PCI-E slot, conected the crt cable and turned de PC on, he GPU chassis fan started normaly, but there's no image on...
First off all please make sure that your crt is connected to your graphics card directly not your onboard crt port.
after this please go to your bios and choose your pcie card as your default video card.
Once done please save all sitting and restart your pc.
Hope this solve your problem.
Regards: Kartikey
Apr 14, 2011 | EliteGroup ECS NGT430C-1GQR-F GeForce GT...
About the size of onboard graphic
ASUS P5KPL-AM SE
Onboard-Video: Intel GMA 3100 Graphics Controller, w/ 256MB Shared Memory
Video Slots: 1x PCI-Express x16 Slot
source: http://www.smksuperstore.com/product/P5KPLAM_SE-52785.aspx Note: I quickly checked Asus's website and the manual (
http://www.asus.com/Product.aspx?P_ID=xs6iinKxu0y5agcg
) but it didn't appear to give a direct answer.
Also note that even if the motherboard supports both onboard+PCI-E, G31(GMA3100) graphics wouldn't help much at all, trust me. You'll want to buy a new PCI-E card if you plan on doing any gaming. Not knowing what game(s) you plan to play, your budget, and what processor you have makes it tough to suggest an exact video card. So, check out this site to select the best card for your budget and game play:
Best Graphics Cards For The Money
http://www.tomshardware.com/reviews/best-graphics-card,2362.html
You can definitely get a real good card for under $100. Perhaps a Radeon HD 4850. Lastly, I highly recommend you buy from NewEgg.com.
Aug 10, 2009 | ASUS P5KPL-AM SE Motherboard
Graphics card compatibility
That mobo is here"
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138090
It says it has a PCIe x16 slot, so really good graphics cards running on PCIe x16 will work on it.
This is a list of the PCI express x16 cards you can buy:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201069609641&name=PCI%20Express%20x16
Generally the more they cost the better the performance but that is another story =)
If you wanna to hit me up with your full PC specs of CPU, RAM, Windows version, etc, i could recommend cards for certain games.
It also has PCI so older and less powerful PCI cards can likely be used.
Mar 19, 2009 | Computers & Internet
Problem with an deskpro pci graphic card
  1. with this age of computer it is still quite possible that the motherboard itself has a jumper that needs to be properly arranged to disable the onboard video.
Dec 23, 2008 | Compaq (1 MB) Graphic Card
My monitor's power light is on, but there is no display.
Something may be wrong with your video card. Or it could just be loose. Open your CPU, remove your video card (the PCI card where you attach the monitor cable) and reinsert it. Make sure that you remove static electricity from your hands by placing it onto the sides of your CPU casing before handling the video card.
Sep 23, 2008 | Computers & Internet
Pci express slot
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Jul 18, 2008 | ASUS M2N-MX Motherboard
Video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
Nov 24, 2007 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
