Question about HP Compaq nx6325 Notebook
Ok... here i am again... with another problem... this time is with my bluetooth device on my laptop... it was working good and when i installed Fix It Utilities antivirus, suddenly it jus stopped working... it's enable and in the device manager its saying that it's working properly... but when i right click on the tray icon it shows me "Start the Bluetooth device" and the icon is red(blue+red)... when it should be white(blue+white)... so can i get any worthy help on that problem that im facing...
  • baddie_69 Jun 01, 2010
    what would be the driver to download for HP Integrated Module with Bluetooth 2.0 Wireless Technology...
    Sergeant:
    Champion:
  • 256 Answers
Try downloading drivers again install it..
Posted on Jun 01, 2010
Discover Bluetooth Device Not Available
uninstalled the rom
bad idea that.! why mess with ROM. ouch.
test the PC on other BT devices, if it works then the PC is good.
even a BT head set, mouse, or any other vast numbers of BT devices, (not apple sure)
Mar 08, 2017 | HP Pavillion DV6227 Notebook
Ok then how would i set up alap top to use bluetooth
If your laptop is bluetooth enabled then install the bluetooth driver. When the bluethoot driver is installed and the bluetooth is switched on then the laptop will detect any bluetooth device that is within range and you can select that device to connect with your laptop.
Feb 22, 2012 | Computers & Internet
How to activate bluetooth
How to Use the Bluetooth in the Gateway Laptop
ou may have bought a new Bluetooth-capable device like a Bluetooth mobile phone, and may want to load some ringtones or media files that you have stored on your Gateway laptop. This might be the first time you are ever attempting to communicate with a Bluetooth device using your laptop. Normally, Bluetooth has to be enabled on both the devices attempting to communicate. It is no good if Bluetooth is enabled on only one of the devices. All attempts at communicating via Bluetooth will fail. However, if Bluetooth is enabled on both the devices, bringing the two in close proximity is enough for the devices to detect each other. While this is what should happen and it happens most of the time, sometimes the devices need a helping hand. Here's where you come in.
Instructions
1Enable Bluetooth on the mobile phone. This procedure is dependent on the make and model of the mobile phone. You need to see the user manual accompanying your mobile phone to see how to enable Bluetooth.
2Turn on your Gateway Laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry.
5Select the Local Services tab. Startup type for all services should be set to "Auto."Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
Tips & Warnings
If your laptop does not detect the mobile phone even now, turn off the phone and turn it on again while keeping it close to the laptop.
Jan 07, 2012 | Gateway MD7820U (L-LX.W730X.007) PC...
I need to install bluetooth modem for my laptop HP compaq mini110c-1111ev pc
I am glad to HELP YOU!
All you have to do is to PAIR the both devices. So TURN ON the bluetooth on your HP mini and turn ON the Bluetooth Modem.
Right-click on the Bluetooth icon on your laptop and choose ADD DEVICE and let it discover the modem.
Once discovered add it as a paired device and [... probably] you ill have to input the PAIRING CODE for your modem.
Once paired click OK and you're good to go!
GOOD LUCK!
________________
Windows 7 tips
Apr 24, 2011 | Computers & Internet
I've been trying to connect my mobile to my vaio laptop via bluetooth, but it tells me peripheral device not found when i tried installing the driver software. My bluetooth used to work fine, this problem...
Check on esupport.sony.com for any available driver updates for the bluetooth software. Otherwise, installing the driver again from the Sony site should fix the issue.
Feb 28, 2011 | Sony VAIO Notebook
I have acer aspire laptop 5738 .i installed driver for blutooth but still i am not able to connect it . it is giving me error saying bluetooth device not found . please help me out.
Hi
Here are the solutions :
Restart your computer and press F8 when boot up and choose safe mode, then enter. Restart again and run on normal mode. If your bluetooth is working before, safe mode will fix the error on the drivers because of faulty installed driver or software or drivers conflict with multiple same drivers installed.
If you just new installed the driver, the bluetooth driver is not compatible with the operating system. Try to go to device manage, right click and uninstall the driver and install again. Or just update your driver whenever you install the bluetooth driver. Normally when installing softwares or drivers, you need internet connect when installing drivers to get updates if ever. restart your computer to take effect the hardware settings.
I hope it helps you.
Jan 13, 2011 | Computers & Internet
Bluetooth device not found
Try reinstalling the drivers again my friend
Feb 16, 2009 | Acer Aspire 5315 Notebook
Acer travelmate 5520 bluetooth not working
Check if the drivers of your bluetooth device are installed in your computer
Nov 13, 2008 | Acer TravelMate 5520 Notebook
Sony TXN17P Bluetooth vagaries
Hmmm...
If you can connect manually but it is not connecting automatically, then you have a settings problem either on the phone (less likely) or within the applet on your laptop controlling the bluetooth services. Try that first before reverting to the XP bluetooth software; usually when companies include custom bluetooth software, it is necessary.
If you cannot connect at all...
If you have tried to pair the laptop with the Nokia using the Toshiba applet and it never seems to work, and you've tried adjusting the settings on the phone and in the applet, and you know the bluetooth card is on and running normally on the laptop, I'd suggest uninstalling the Toshiba drivers and software through CONTROL PANEL and then rebooting and see if XP takes control of the bluetooth adapter. If not, try uninstalling the bluetooth hardware in DEVICE MANAGER and then rebooting, which will force XP to do a clean install (including bluetooth support software) and see if this gets you to normal operation under XP. If not, go to the SONY web site and, again, do a clean install of their bluetooth support software for your model, and try again from there. One of these combinations is pretty sure to work.
Make sure that if your laptop has a physical button on it to activate the bluetooth radio, that it is on, and that the device is enabled through device manager/network/connectivity. Any one of these being mis-set can (especially on Sonys) result in a confusing set of inexplicable failure conditions.
Good luck...
Nov 17, 2007 | Computers & Internet
HP Compaq nx6325 Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
