Radio Communications Logo
Posted on Jun 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi im tring to look for police channels for my scanner.how do i get the numbers.
Anonymous
Level 3:
Genius:
  • Master 1,274 Answers
  • Posted on Jun 01, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1274
Questions
0
Helped
315864
Points
3479
You can get them at www.RadioReference.com ...hope this was helpful...
Pro-2044 police scanner. How can I program it manually?
1. If the scanner is scanning, press MANUAL.
2. Using the number keys, enter the channel number where you want to store a frequency.
3. Press PROGRAM. BANK and the bank number, the selected channel number
and CH, PGM, L/O (if the selected channel number is empty), and 000.0000
MHz appear on the display.
4. Using the number keys, enter the frequency you want to store into that
channel, including the decimal point.
NOTE: Your scanner automatically rounds the entered frequency up to the
closest valid frequency. For example, if you try to enter a frequency
of 151.473, your scanner accepts it as 151.475.
5. Press E to store the frequency.
NOTE: If you enter an invalid frequency in Step 4, the scanner displays
Error. Press CLEAR, then repeat Steps 4 and 5.
6. To program the next channel in sequence, repeat Steps 3-5. To program
another channel (not in sequence), repeat Steps 2-5.
What scanner can pick up nexedge
Go to :
http://info.uniden.com/twiki/bin/view/UnidenMan4/UnidenScannersUsersGuides.
4helpful
3answers
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Im trying to find a police channel in my area and cant what do i do
For a comprehensive database of active frequencies and systems in your area, plus a lot of other useful scanning info, visit:
If you are in or near a large metropolitan area it's possible that your police communications are now using a trunked radio system. If that's the case you will not be able to monitor them with the BC92XLT - you will need a scanner designed for trunked systems.
BillB
1helpful
Motorola k7gt9500 police channel in manassas virginia?
Your Motorola radios operate in the FRS/GMRS band, which is at 462 MHz. Police, fire, EMS services, etc. operate in the 150 or 800 MHz bands. Your radios cannot receive public service transmissions, and they cannot be modified to do so. Monitoring public service transmissions will require a scanner.
For a comprehensive database of active frequencies and services in your area, visit:
For a good listing of available scanners, visit:
www.ScannerMaster.com
Citizen band scanner'
Thanks I solve the problem by going online to the local police dept. in my area and located the channels I needed' then program the scanner.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
