Question about Black & Decker String Trimmer Cordless 12" 18V
My Makita Petrol Strimmer won't start
Was working a little while ago but know just won't start / fire
  • 66 Answers
If it is a gas (petrol) trimmer...then most often it is in the on/off switch on the handle. Before you go tearing anything apart...rock the on/off switch a few times to see if it helps. www.nnyparts.com
Posted on Jun 01, 2010
My makita dbc4010 petrol strimmer was working then not used for 3 months now it wont start,plus now theres no spark
Parts: http://www.ereplacementparts.com/makita-dbc4010-brush-clearing-saw-parts-c-97_16558_10177.html?gclid=CKyA0JLti80CFQetaQodzw0DaQ Use fresh gas and oil, 2 stroke 40:1. Clean/replace air filter and spark plug.
Sep 25, 2015 | Makita Garden
My RST210 2 stroke petrol strimmer won start it has a spark at the plug also the plug is flooding so fuel is getting through but non start ? Great full for any ideas
Often it's the easiest thing that stump us. Try changing the spark plug first. Sometimes a spark plug just won't fire under load, i.e., while it's in the cylinder but will spark if you have it removed. There are checkers for this, but it's a lot less expensive to just replace the spark plug. Do that first and let me know.
Sep 28, 2014 | Makita RST210 2 Stroke Petrol Line Trimmer...
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
How do I start a B&Q Petrol strimmer
IF IT HAS THE PRIME BUTTON.
press several times slowly. turn on/off switch to on. select full choke. pull starter until it tries to fire but no more than seven times. select half choke and do the same. if it fires up allow to tick over for a couple of miutes then open choke fully. if it doesnt fire leave for 10 miutes then start all over again. good luck
Aug 12, 2010 | Garden
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
Having problems starting Makita strimmer. There is quite a lot of smoke coming out and then it stops. Have looked at spark plug -clean, and cleaned air filter. Could the problem be the petrol and oil mix.
Use 50:1 gas/oil with a GOOD QUALITY 2-cycle low-ash synthetic oil.
Remove the muffler and check the spark arrestor isn't partially blocked.
With a clear muffler, and the mix as described, there will be hardly any smoke at all.
May 09, 2010 | Black & Decker String Trimmer Cordless 12"...
Petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Sep 14, 2009 | Garden
I have a rhobi strimmer only 2 years old wont start
I presume this is a petrol one. The fuel can dry in the carby and stop the unit from starting. Use fresh petrol.
I am not sure about the ryoby unit, but if there is a air filter, take it out and dip it in petrol, then try to start with the normal proceedure in the manual.
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Black & Decker String Trimmer Cordless 12" 18V Logo
337 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
