Question about Motorola Mobility RAZR V3
On/off and it won't stop
My phone will cut itself on and off and i don't know why
  • kathy76 Apr 08, 2008
    my phone keeps cutting on and off what do i do?
  • Anonymous Aug 07, 2008
    my phone wont cut on unless it is on the charger and when it is on the charger it wont cut all the way on it eill just cut half way on then it just keeps going off then when i do take it off the charger it wont cut onn
    Brigadier General:
  • 7,752 Answers
Try changing the battery if that does not work then try having the phone reflash.
Posted on Apr 14, 2008
6ya staff
SOURCE:
Sears typewriter
when you shift there is a n adjustable stop, the rubber pad probably rotted away. You can usually readjust the stop to make it work. The rubber pad is only for noise reduction.
DickyO
May 28, 2013 | Office Equipment & Supplies
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
My camera stopped working on my phone. Is there any way to fix it?
i don't know how to get a free video handler to my phone
Dec 26, 2011 | Sanyo SCP-2700 Cell Phone
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Camera sx110 won't start when start button is pushed
I'm going to ask the silliest of questions: Did you check the batteries?
I mean, I know they are there, but are they any good?
What type are they? Alkalines sometimes just don't cut it.
You need the Lithium type. They are expensive initially but they last a long time -if you don't use the flash excessively.
Jun 16, 2011 | Canon PowerShot SX110 IS Digital Camera
2001 Dodge Ram 1500 2WD truck. From time to time the turn signals won't blink. They light up but do not flash. They will sometimes begin to blink and then stop blinking. Sometimes they blink,...
check the earths on the lights and the bulb wattage ,it should be 21watt ,but if its the weird funny system on a american car then who knows ,where the stop light is the indicator and it flashes red and cuts out ??
May 25, 2011 | 2001 Dodge Ram 1500 Truck 2WD
Were are the main wires to wire up a towbar are they behind the rear side panels or under rear bumper and where is the best site to get a light diagram thank you
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done
May 21, 2011 | 2000 Suzuki Grand Vitara
How do i reset the password for voicemail on a Panasonic KX-T7735
The only way to reset the password if you don't know or remember the original is to call the provider. If you don't know the customer service number, you can always dial 611 from the mobile phone itself.
May 04, 2011 | Cell Phones
My t mobile wing keeps cutting off and turning itself back on. the screen fades out and goes blank.
i know this sounds silly but lick the battery. save your numbers to the sim card and reset your phone.. you have to keep reseting your phone.. this will work for about 2 days with no problems but if you keep doing it you won thave to worry bout it thanks
Apr 23, 2008 | Lands Phones
Motorola Mobility RAZR V3 Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
