Question about ViewSonic VA2226w 22" Widescreen LCD Monitor
Mouse movement is not clearly visible & get more H'lin brightness
ViewSonic VA2226w 22-inch wide, Model No.: VS12071
Serial No.: QX 6081642708 Gifted to our Trust 1 year back,.
We have some problems:
1. Mouse movement is not clearly visible
2. Getting horizotal lines with excessive brightness
We have already tried reinstalling without any solution
Kindly solve the problem immediately.
Dr. S. Nanda Kumar,
Managing Trustee
Annamacharya Bhavana Vahini, Hyderabad. www.annamayya.org
  • 11,361 Answers
Have somebody take a look at the capacitors in the power supply first, look for caps that are leaking/bulging top, very common failure in LCD monitor.
Please see some failed bad caps album and failed VIEWSONIC monitors due to bad caps here:
http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps:
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 01, 2010
We have a Viewsonic VA2226W that goes to black screen after 15 seconds or so, is it toast or is there a way to fix?ViewSonic monitor VA2226w
Make sure you are supplying a valid timing mode to the display. Call ViewSonic technical support to resolve your issue.
Oct 01, 2014 | ViewSonic VA2226w 22" Widescreen LCD...
What year of mfg.108125 ?
Do you know what model it is?
Beings it's a .22, I'm thinking it's a Model 4, but usually those were a 22 1/2" barrel length.
1890-1933
Total production - approximately 356,000
If it's a "take-down" model, it COULD be a Model 6.
1901 - 1933
Numbers 00001 - 498,000
As far as serial numbers, a lot of them had the serial number on the side of the top tang, visible only with the action out of the stock.
Not all Remington serial numbers were consectutive for the model.
Military models were often numbered by the contract and commercial guns marked with batch numbers having little relationship to the time of manufacture.
May 11, 2014 | Sports Collectibles Remington Rolling...
Viewsonic - VA2226w - dual monitor configuration. Monitor is black / no image- all test pass showing monitor is functioning properly.
Swap this monitor with the main one.
If it works, you may simply not have the secondary output enabled in the operating system.
In Windows for example, in the video properties, there's a place where you choose which video card you're dealing with (and/or which output or monitor) and there's a checkbox that says "extend my desktop to this monitor"
If that's not enabled, monitor 2 will be blank !
If the monitor doesn't work in the same connector that the working monitor is in, you may have bad capacitors in this one.
Watch the video below on how to fix that issue.
Mar 25, 2011 | ViewSonic VA2226w 22" Widescreen LCD...
I have a viewsonic VA2226w and when i'm away from my desk for more than one hour the monitor display dims. the work around i need to do to make it go to it's original state is to turn off the monitor and...
Look for bad caps in the power supply section, that will be the first place to look. 90% of LCD monitor failures are due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 27, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
After waking from sleep mode, monitor resolution is a mess!
Try reinstalling the graphics drivers. and possibly a different graphics card.
Apr 14, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226W LCD Monitor unlock power button
Try holding the vol+ & vol- or hold the vol+ & Menu and lastly try the ch+ & ch- buttons. When doing this you must do it from the tv not the remote, and hold them down for ten seconds or until it says it has unlocked.
Apr 04, 2010 | ViewSonic VA2226W LCD Monitor
When Monitor has been switched off for 8 hours it takes 5 minutes to get back up again. Once up it will work perfectlt
This monitor is more than 2 years old, time to look for bad caps with bulging top in the power supply, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
Installing Ubuntu after vista install gives "out of range"
http://www.tech-tips-now.com/2008/11/12/how-to-dual-boot-vista-and-ubuntu-810-part-7/
this is great guide to set up a dual boot option on your on pc
Mar 16, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226w 22" Widescreen LCD Monitor Logo
101 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
