Question about Sylvania LD-155SL8 15 in. LCD Television
When I tried to turn on my tv it made an odd noise, turned off and would not turn back on, even though it worked just fine about 10 minutes before I tried to turn it on again. Now it won't turn back on, even after trying it in another outlet. What should I do?
    President:
  • 1,099 Answers
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Jun 01, 2010
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
KV-27TH70 SONY TV Shuts Down for no Reason
hi there, normally bad/broken connections in the horizontal or on the flyback. hjope this helps.
Aug 04, 2008 | Televison & Video
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Logitech x-230 - left speaker not working when used with 360
my speakers plug into my comp. by that little cord with the green end piece. and i have to figit around with it just to get one speaker to work, can i fix it or do i have to buy the whole set again?
Mar 10, 2008 | Logitech X-230 Computer Speakers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Sound but no picture
Get on the phone to Samsung at 1-800-522-7341.
Sammys are known for this knd of odd problem.
Even if you are out of warranty, they have been known to work with you.
Count your blessings it is usually worse.
Jan 01, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung LN-S2641D 26 Inch Wide LCD HDTV w/ Integrated ATSC Tuner Color Issue
if your tv is on warranty take it back to the agent who you buy it from.if it is out of warranty have a tech look at it for repairs.goodluck.
Apr 03, 2007 | Samsung LN-S2641D 26 in. LCD HDTV
Sylvania LD-155SL8 15 in. LCD Television Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
