Question about Epson Office Equipment & Supplies
Epson RX595, Mac OS X, print failure Cyan low and replaced, new supply recognized, ne ow both cyan and yellow fail the print test, have cleaned thehead twice.
  • 2,069 Answers
Do these steps to make sure the cartridges are correctly installed:
1. Make sure the Epson Stylus is turned on.
2. Make sure the CD/DVD tray is not inserted and the output tray is in the paper printing position.
Posted on Jun 01, 2010
  • Muzahura Frank Jun 01, 2010
    3. Do one of the following:
    - If your printer indicates that an ink cartridge is expended, press OK.
    - If your printer does not indicate that any ink cartridge is expended, press Setup, select Maintenace, and press OK. Then select Change Ink Cartridge and press OK.
    4. Open the scanner.
    5. Open the cartridge cover.
    Caution:
    do not open the cartridge cover while the print head is moving; wait until the cartridges have moved to the replacement position.
    To avoid damaging the Epson Stylus, don’t move the print head by hand.
    6. Press down all the ink cartridges until they click into place to make sure they are properly seated.
    Note:If a cartridge is properly seated already, you may not hear a click.
    7. Close the cartridge cover and push it down until it clicks into place.
    8. Close the scanner.
    9. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
Why too much yellow and red no greens or blues ?
Inkjet printers use additive pigments. CMYK, Cyan, Magenta, Yellow and Black. It sounds like you're not getting any Cyan ink to the paper. Either your printer is out of Cyan ink, or your Cyan print head is clogged.
Go into your printer's Properties and run a Nozzle Check. It will print a series of lines with each color. There will probably be a big empty space where it tried and failed to print Cyan. You can try cleaning the print heads, but if you're getting NO Cyan that is unlikely to work.
If you're lucky, your printer is one of the ones that the print heads are built into the ink cartridge so replacing the cartridge will resolve the problem. If you're not, you might need to get it serviced (or probably more cost effective, buy a new printer).
Apr 30, 2014 | Epson Stylus CX5700F All-In-One InkJet...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Cyan cartridge prints spotty.
Your print head is probably clogged. If you have already tried the cleaning cycle, it's time to take the printer into an Epson repair center to find out what the problem is. More than likely they will have to replace the print head.
Jul 11, 2009 | Epson Stylus C84 InkJet Printer
Epson SX 205 ink insn't low but is not printing yellow or green
Status monitor just show approximately, not real level. It might be yellow and cyan ink is out actually.Others, yellow and cyan nozzle may be clog. Check nozzle, do head cleaning. Check nozzle again.
Jun 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Thin cyan lines across entire image and into border area
rrrosz,
From your description, it sounds as though you have a faulty main board in the printer. This type of problem is unlikely to be software, but if you want you can try to reload the software. However I doubt it will help.
The unit will require a professional diagnosis to confirm as it will needed to be tested on a test pc in a registered service centre.
There is a slight chance it is the printhead, but I have my doubts about that also.
Gremlin11
Dec 13, 2008 | Epson Stylus Pro 4800 InkJet Printer
ARC ink cartridge = Mac color MISmatch?
change the cartridge with the correct color that is shown in the printer cartridge tank container, The inks in the Arc cartridge may be filled with the wrong color
May 15, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
