Question about iRobot Roomba 530 Robotic Vacuum
I have a new 530, I charged it overnight, used today just great but now it is on charger and charging light will not come on, only green light on station is on but not on the clean button it has no light. I removed the battery and reinstalled but nothing
  • 458 Answers
IN WARRANTY EXCHAGE NO SERVICE
Customer Service at 877-855-8593
Posted on Jun 01, 2010
Why is there no green light or red docking showing it is charging?
Sometimes the contacts between the battery and the iRobot get corroded...you can try using a small piece of sandpaper to lightly scuff/clean the battery contacts. Once you put it back together, try the reset function mentioned previously.
May 26, 2015 | iRobot Roomba 530 Robotic Vacuum
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Red light flashing very fast and not charging fully
How long is it charging until the light goes from flashing red (no charge) to yellow to finally green (full charge) ? If it's not at least 2 hours, sorry I don't have my Roomba papers available, so I'm guesstimating here, it's not getting a full charge. If you can put a voltmeter on the " fully charged" battery pack, that might tell you if the charger is the problem. Clean off the metal contacts where Roomba meets the two metal contacts on the charger. Also just because a battery pack or set is new doesn't mean it's functional. I had a new Apple battery for my laptop that didn't work when I replaced an older one.
Sep 26, 2014 | iRobot Roomba 530 Robotic Vacuum
New Roomba Battery Not Holding Charge - charged once then died
It is possible for the charging system inside the roomba to call it quits. What I did to remedy this, since my roomba was out of warranty and I did not want to scrap it, was to buy a charging base on ebay. This charging base accepts different types of roomba batteries and even the scooba battery. The inconvenience is if you have a newer model roomba that has the battery inside, then you will need to remove the screws on the bottom plate to remove the battery. Hope this helps.
new-roomba-battery-not-holding-charge#solution-section-qgwpio3es2ee0iuiltq5rfxr-1-0.jpg
Jan 23, 2014 | Roomba Robotic Floor Bagless Vacuum
Dyson dc30 charging issue
Defective replacement battery - unable to charge/recharge.
Jul 11, 2017 | Vacuums
Roomba 4106 new battery charged but wont start
see the diodes, resistor, capacitor inside for test.
since the battery is new, the power charger is faulty, power regulator IC is bad.
God bless you
May 16, 2012 | Roomba 3005 Pro Robotic Vacuum
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
New battery. Charged for 24 hours. Light is green, but after 20 seconds light turns red and it stops.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Sep 25, 2009 | Roomba Robotic Floor Bagless Vacuum
IRobot 530 charges intermittently
Reset the Roomba: hold down "spot" and "dock/demo" for fifteen seconds, then release and listen for the tune. Then charge the Roomba overnight. The next time you run it, the unit should run longer. If not, call support and let them know you may have a battery problem. 1-877-855-8593 (I strongly encourage you to have the Roomba with you if you call.)
Aug 30, 2009 | iRobot Roomba 530 Robotic Vacuum
iRobot Roomba 530 Robotic Vacuum Logo
185 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
