Question about Brother Office Equipment & Supplies
Cutter jam on my brother intellifax 620
Cutter jam error on my brother intellifax 620
checkitright
  • 1362 Answers
SOURCE: Brother Intellifax 2820 repair + automatic document feeder + sensor
Here is the service manual it should help :
http://www.feedroller.com/Store/Service%20Manual/FAX2800,%20MFC4800%20Service%20Manual.pdf
Posted on Oct 31, 2007
marsrover
  • 682 Answers
SOURCE: Brother Intellifax 4100
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Posted on Mar 03, 2008
  • 120 Answers
SOURCE: brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Posted on Apr 23, 2008
SOURCE: Brother Intellifax 2820 JAMMED
Clean the rollers, but also check the drum/toner. at the front there is a peice that breaks on occasion that will cause a jam.
Posted on Dec 17, 2008
  • 10 Answers
SOURCE: my brother intellifax 5750 has a paper jam and it
make sure no paper is in unit then turn off and unplug for 5 minutes then plug back in and turn on
Posted on Mar 17, 2009
Paper jam sign appear all the time
If you get this error check for paper jam and see if the paper cutter is seated right and is not defective. You can try cleaning the cutter and lubricating it, even then issue not resolved replace the gear train.
Dec 10, 2010 | Brother Office Equipment & Supplies
Document jam
THIS SOUNDS LIKE YOUR PAPER JAM KNOCKED OUT A PAPER SENSOR IN THE PAPER PAPER! PLS CHECK FURTHER OR YOU WILL HAVE TO GO TO A SERVICE CENTER BROTHER TECH
Jan 16, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Brother 2820 Says clear scanner jam and press stop
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2800 --message turn off and call Brother
what you want to do is unplug for a couple of minutes while checking to make sure there is paper jammed anywhere in the machine, remove all your paper from supply as well. then time how long it take to warm up or the error code comes up.
mikey
Mar 13, 2008 | Brother IntelliFAX 2800 Laser Fax
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 770
did you take out the cartridge and look inside, the papre might be under the cartridge.
Oct 26, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Poor line condition error Brother intellifax 5750e
Poor line condition is an error referring to the phone line itself. Even though it may sound clear small amount of static confuse the fax machine and cause the error. Try using a new phone line. If that doesn't help I recommend getting a line filter from OfficeMax
Oct 11, 2007 | Office Equipment & Supplies
135 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
