Question about Panasonic Lumix DMC-FZ28 Digital Camera
System error: zoom message with Panasonic Lumix FS15 camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 12, 2010
  • 1 more comment
  • cgodwin589 Nov 15, 2010
    The link that you posted helped, it was one of the steps you didn't mention.. I had taken a blow dryer (as opposed to me blowing and water getting inside) and aimed it at the lens. It was able to push out whatever was in the way. Thank you thank you thank you!
  • Jameson78 Mar 13, 2011
    Thank you lock123!
    I didn't have my Lumix for long when I got the System Error Focus error. I basically thought I had to buy a new camera and it had been sitting in a drawer for months. I had been looking at new cameras and decided to check Google just for the heck of it, to see if I could somehow get the Lumix to work, not expecting much, as I figure cameras are pretty sensitive devices.
    I tried the powering it on and off lens side down on the table and that didn't do anything, so I figured I'd do the whack it against the palm of my hand as a last ditch effort. Wouldn't you know it... It worked!!! The camera now seems as good as new. If nothing else works, try this people! I just hit it firmly but gently with the lens closed and it worked perfectly right away. Thanks!
  • mohaco Aug 10, 2011
    I was getting the zoom error message. Took my camera to Henry's, they wanted $300.00 to send it out to be fixed. I decided I would just start looking for a new camer. I started shopping online and came across this web site. I tried turning the camera on and off while plugged into my computer, nothing happened. So, decided since I was replacing it I would try banging it against my palm. It worked. Once the zoom opened I used a small computer vacuum and cleaned around the lens. Good as new. Thanks so much.
3 Suggested Answers
lock123
  • 6831 Answers
SOURCE: I have the same camera with the same error
Hello
Regards
Andrea
Posted on Sep 30, 2010
SOURCE: System error: zoom message with Panasonic Lumix FS15 camera
I had the same problem, i switched the camera on in capture mode and zoomed in and applied a little pressure to the lens which made a slight click but retracted and has worked fine since. I may of just been lucky but the camera is fully functional again, could be worth a try.
Posted on May 20, 2011
How to slove system error(zoom) of my panasonic lumix dmc-fs15
You can't. it is cause by something blocking the gears or the lens being knocked to the side. Here is the online service form
http://www2.panasonic.com/webapp/wcs/stores/servlet/RequestCenter?storeId=15001&catalogId=11017
Jul 01, 2012 | Panasonic Lumix DMC-FS15 Digital Camera
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
System Error (Focus) ...Lumix DMC-FS15 works, pauses, then results in a white error screen with the following error message:
My camera started bringing up "system error (zoom)" and it was completely inoperable. I would turn it off, but the lens wouldn't retract unless I applied slight pressure to it. I was able to FIX this problem by applying some lubricant oil to a Q-tip and swiping it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work its way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
Oct 08, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
I have an FS15 and get the error message, 'system error zoom' the lens is not centred and does not retract. The camera has not been dropped and is c15m old.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
Have a Panasonic DMC-FS15 and get message saying "turn off and back on" followed by "system error (focus)" Have tried taking battery out for length of time and making sure charged, blew...
I have this exact problem. I note, your issue is happening at the same time. Weird.
Tried a variety of other "fixes" but none seemed to solve this issue. Thoughts?
jeremy.wolf@gmail.com
Dec 03, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Sep 19, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Jul 20, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic Lumix DMC-FZ28 Digital Camera Logo
1,439 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
