Toshiba A-135 Notebook only works with a charged battery but will not work with the AC Adapter. Is the system port bad?
  • 50 Answers
It could be that the DC jack (what you plug the AC adapter in to) has become loose from the motherboard, or it could be the adapter itself. Plug the adapter into the computer, and -gently- move the cord, just a bit. Does the end in the computer move around a little? If so, you'll want to get it looked at.
If the problem is with the adapter itself, you'll need a replacement. I suggest calling up Toshiba and see about getting a replacement adapter. If the computer is less than a year old and falls under Manufacturer's warranty, any parts that you may need should be covered.
Posted on Apr 09, 2008
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Jun 17, 2012 | Toshiba Satellite (p25-s5093) PC Notebook
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
Confuse the function of the laptop adapter Toshiba satellite pro
The AC Adapter has to be used which is compatible with the particular model of the Notebook. You can refer the User Manual came with the Notebook to know the exact model number of the AC Adapter. To confirm whether the AC Adapter is working or not you can check the LED light of the AC Adapter, if the LED is glowing then it is working fine.
The function of the AC Adapter is to charge the Battery of the Notebook.
You can also use the Notebook by connecting the AC Adapter while it is charging or when it is fully charged.
Mar 27, 2011 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Toshiba A35 S159
you forgot the most important item in the whole equation the battery.How long will the computer stay on with the battery?One quick fix,try using a toothbruch to clean the contact on the battery and on the computer.This might work.I think the computer is fine. The battery might be bad,
Sep 28, 2009 | Toshiba Satellite A35-S159 Notebook
AC Adapter dosen't work
Check if there is a green light on the Adapter, on the black Box, if it is not there, please get a new adapter
Jun 02, 2009 | Toshiba Satellite A135-S4527 Notebook
When i plug in a/c power adapter to my toshiba laptop it sparks
Sounds like your ac port is broken. If you can not run it off ac or battery this would be why. There is no current flowing to the motherboard. Is the ACjack loose?. If so you need your ac jack repair. A local repair shop can do this. Unless the system is still in warranty. You should be able to call support and tell them that your notebook is not working due to a malfunction ac port.
I hope this helps you.
Feb 18, 2009 | Toshiba Satellite 1135-S155 Notebook
You may have to use the battery and the ac adapter at the same time. it could be that your battery is not yet charged that's why its not working.
if you want to know if there's something wrong with one of the components of your can try this...
turn your computer on with just the ac adapter plugged in - if working then try both ac adapter and battery.
if your system will not turn on with just the ac adapter plugged in, it could be there's something wrong with the ac adapter or with the motherboard of the system
Oct 05, 2008 | Toshiba Satellite A65-S1065 Notebook
Toshiba Portege 7140CT battery problem
Your ac adapter may be the problem. Is the adapter in good condition. Try using your friends ac adapter since you have the same model laptop. If it charges up your battery and the light stays on your adapter is at fault. Then replace your adapter or the part of it that is at fault. It could be the plug or base. If that does not solve your problem check your dc port on the laptop itself. Shut it down. On the back of your laptop where you plug in the ac adapter there is a pin. Does the pin move? If it does then you have another problem. The port may need replacing which most repair shops don't do. They usually replace the main board which can be costly. Hopefully that's not the problem. Let me know if either of these are not the case then we can go from there. Hope this solves your problem
Sep 08, 2007 | Toshiba Portege 7140CT Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
