Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
My canon powershot sd 1200 wont turn on i have recharged the battery. what else can i try?
    President:
  • 1,382 Answers
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Posted on Jun 01, 2010
What do I do when lens would not open?
  • is your batteries fully charged?
  • if you are using old rechargeable batteries try replacing them
Aug 09, 2014 | Canon PowerShot SD-1300 IS 12.1 Megapixel,...
I turned off my camera (Canon powershot G9). After 2 seconds i turned it back on the lens popped out but the camera wouldnt turn on. Now the lens is still popped out, wont go back in. I tried recharging...
hi would you tell me more about condition? does it power on, do you see back of lcd any message, if power on, then you have lens unit is defective. no power at all, then you have either power control pcd(dc/dc convoertor) or main pcb. If main fail, then you have to send canon factory. but lens unit or power pcb problem can solve in your local repair shop. They would chage you around $65 to 165 depend on what they really want to charge. Thanks and best regard!
May 23, 2011 | Canon PowerShot G9 Digital Camera
Canon Powershot A470 - asks to 'change battery' every time it is turned on, then turns off immediately. This is so even when new, fully charged batteries (different brands, rechargeable, non-rechargeable)...
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
Jan 08, 2010 | Canon PowerShot A470 Digital Camera
A580 wont switch on with new correctly inserted batteries
Check for battery current ratings, Canon cameras need AA batteries with current rating above 1200 mAh, I use Energizer rechargeable batteries for my Canon Powershot SX110 IS. The batteries last more if we use the flash option wisely.
Jul 25, 2009 | Canon PowerShot A580 Digital Camera
My Canon sd 1000 won't power on. Battery is OK.
Check to make sure the batteries you are using have enough strength and volt power, if not it wont work. If they are really cheap, and last only a weak in the remote, they wont power up a camera.
Jan 21, 2009 | Canon PowerShot S1 IS Digital Camera
My Power button isnt working
There could be several thing that could cause this problem like a bad lens. the battery might have to be left out of the camera for 24 hr to discharge the battery, a damaged main board. a defective power button. try taking out the memory card to see if that fixes it. repairs on this unit can start any where from 65.00 and up. goto www.digitalcamrepair.com if you need repair service.
Dec 09, 2008 | Canon PowerShot SD1000 Digital Camera
My canon powershot A530 WONT TURN ON!!!!
Check the batteries, and if they are bad, replace them. If it has rechargable batteries, just get rid of them and try regular alkaline batteries. That should be the fix.
Oct 05, 2008 | Canon PowerShot A530 Digital Camera
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
655 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
