Some usb ports don't work properly - Computers & Internet
  • 70 Answers
You need to change the motherboard
Posted on Jun 01, 2010
I think, i am having a usb port malfunction. i just formatted my lg-ibm xnote lm50a with xp3 and installed all the drivers but all my usb ports don't function. it does not detect printers and mouse...
Have tried installing the CHIPSET Driver for the Motherboard?
Check the device manager for any bang on the devices meaning either a driver is missing or a wrong or incorrect driver is possibly installed, unless a REX "x" is foung beside USB hub then that would mean that is it busted or damaged.
but it is unlikely to have a USB hub/port to be busted unless physically, install the chipset driver and check again make sure you restart the system after installing the CHIPSET driver to make sure that it is properly installed in Windows and that it will detect the USB ports in device manager.
Oct 30, 2011 | LG X-Note LM50 Notebook
The USB ports at the back of the display don't work
If all cables are connected properly, this might be a driver problem.
Oct 21, 2011 | Apple Cinema HD 30" LCD Monitor
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Hello i want to use my motorola w270 to connect to an internet over pc i have installed motorola phone tools v4.5 as well as v5.0 but both version is unable to detect my phone. So please suggest me how i...
Try to plug your phone to other USB port in your PC I will recommend to plug it at the USB port at the back of your CPU. USB supply of power at the back of the CPU is sufficient to make your device function properly so it may be able to detect by the system..mostly device can't recognize by the system because they didn't function properly specially if they are plugged in a USB port who don't have enough supply of power to make them work properly..Hope it may help you..
Jul 11, 2011 | Motorola Mobility W270 Cell Phone
My netgear usb adapter is not working properly and gives error of unsupported operation attempted.please give me some solution
You will need to change the USB port that connects the Adaper to see if the port is working properly or not. If the USB port is working properly then try to re-set the Adapter with the installation disk that came in with it.
Thanks
Jimmy
Jul 23, 2010 | Computers & Internet
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
Usb ports not working
Check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Also check HP's support section on the web for any updated drivers especially for your laptops motherboard / bios
Any exclamation marks by hardware need fixing before you investigate any further
Once you have done that try some of the common fixes below.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
Aug 30, 2009 | HP GbE2c Layer2/3 Ethernet Blade Switch...
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
USB ports setting
Do you have them setup according to your motherboard diagram?
Apr 30, 2008 | ASUS P4S800D-X Motherboard
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
