Question about Poulan Pro Chain Saw 46cc 20"
Chain keeps falling off
My poulan pro 20 (46cc) has very little use (about 10 hrs).
The chain yesterday kept falling off during sawing. i thought it may have been too lose the 1st time but the 2nd and 3rd time i am sure the tension was not the issue. The bar appears straight.
So, for the last time i tightened it too much. i started it and ran it without sawing. In 10 secs, the chain fell off again.
i did notice that when putting the chain back on, the chain itself is not close to the bar side of the gear but it actually was found to be resting on the other side in the 'gap' between the gear and the wall of the body.
Why is the chain falling off?
  • 59 Answers
Have you stripped the studs that hold the guide bar in position? It is the only thing I can think of unless the guide bar has worn down so much there isn't a deep enough groove to guide the chain
Posted on Jun 03, 2010
  • 3 Answers
Mine too is falling off and nothing is stripped
Posted on Jan 31, 2013
Keeping chain on a poulan pro
It is normal for a new chain to stretch during the first 15 min of operation.
You should check your chain tension each time before you start the chain saw. With saw off,
Nov 04, 2016 | Poulan Garden
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
How do I remove the bar on my Poulan Pro PP5020AV
by undo'ing the nut on the side over top of bar , then the entire case cover should lift off that side and then the clutch is visible , slacking up on chain tension screw till the chain can round the clutch and then entire bar and chain should just fall away
Sep 07, 2012 | Poulan Pro PP5020AV 50 cc Gas Powered...
Check the machine is oiling ok, if there is not enough oil to lub the chain it will stretch causeing it to come off, you should see a good spray of oil from the tip of the bar when the saw is reving.
Jun 02, 2012 | Poulan PLN1510 8 Amp 10-in 2-in-1 Electric...
Chain falls off Poulan PP3516AVX
The bar needs to be adjusted. What this means is the long, sliver arm that sticks out and has the chain wrapped around it is in too far. You will need to find what is called a 'set screw' or 'set bolt', which you can loosen and then adjust the bar in and out, which will tighten or loosen the chain. Keep in mind that you should have a little slack on the chain or you will burn up the bar. Also, make very sure that the chain is good shape. A chain that pops on you can take an eye out or fingers off of your hand if you're not careful.
Jun 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Chain keeps turning while in the idle position . Poulan Pro 2075 chain saw.
There will be an idle (Low) speed adjustment screw somewhere on the saw (look in your manual). Adjusting this setting lower will prevent the chainsaw chain from turning in the idle throttle position. Basically you want to set it so the chain has just stopped moving... but you need to set this after the chainsaw has warmed up a little.
Mar 13, 2009 | Poulan Garden
Poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Mar 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
444 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
