I am trying to connect my JVC LCD LT-32E478 to an Apple TV device. Neither component cables nor HDMi cable works. I took it into Apple (Genius Bar) where they proved it was fine. Is there a known problem between the two devices?
  • 12,061 Answers
There should be no problems with the two. A TV device really doesn't "Know" what "Monitor" it is delivering signal too. IT merely outputs a signal, usually, via, HDMI, VGA, or Component, Or Composite, Video signal out. But it must be able to be able to show, A widescreen, enhanced-definition or high-definition TV capable of at least one of the following resolutions:
1080p
1080i
720p
576p
480p If this monitor cannot set these settings then it may NOT be suitable.
manuals.info.apple.com/en/AppleTV_SetupGuide.pdf - United States
http://www.retrevo.com/support/JVC-LT-32E478-TVs-manual/id/2839ag406/t/2/
Remember you MUST be connected to iTunes to enable it to work correctly. Please find it all in your manuals i have included links for you, download and set it up as per the manual, and I am sure you will be able to sort it out.
Posted on Jun 01, 2010
  • vacherrys Jun 02, 2010
    No, there really is a problem. The Apple TV works correctly when connected to a different LCD TV (as demonstrated by the geniuses at the Apple Store). My current TV works with our DVD player, a Wii, etc. I'm 100% sure I've connected everything the way it should be connected. When I read the manual for the JVC, the formats are all consistent with what Apple says it's TV device needs. I tell it to let the video input be automatic (and it's supposed to be able to choose HDMI when it sees that signal). I can't seem to change the size ratio, but all of the available options that the JVC has are consistent with what Apple says.
    When I first tried to connect the two devices, and it didn't work, I googled it. I found on some site a reference by an individual that their HDMI didn't work either, and he was able to make it work using the component cables instead. So then I went and bought a set of those. No go.
    I've tried all the usual things--turn every thing off, wait, then re power and connect one at a time. I've moved existing devices from their "slots" (3 for TV, 4 for DVD, 5 for Wii) to see if it's something about 1 and 2 slots. I've tried putting the Apple component cables into 3, 4, or 5 (where things work today). I'm reaching my wits end because it doesn't make sense, and it should be working.
View input from hdmi-2 JVC LT-32E478
Port 2 must be a dummy, then!
Aug 29, 2012 | JVC LT-32E478 TV
JVC LT-42X579 42 in. LCD TV
If it has more than 1 port try another---If it has component try connection there.
Mar 22, 2012 | JVC LT-42X579 42 in. LCD TV
Can you hook a JVC lt-42x579 tv up to your pc for netflix
It should be as simple as taking an HDMI cable (if your computer has an HDMI output) or VGA (monitor) cable and hooking it into the TV. From there, go to Control Panel and Display Settings, and click which option you want for the TV screen under "Connect my PC to a projector."
Oct 03, 2011 | JVC LT-42X579 42 in. LCD TV
My jvc lcd does not work with my local air tv, i get weak signals
Ur tv is getting a free air DTV right?Not Cable tv,Satalite or Telicom compannies services?Yes,than.Get a better antana like a roof antana or Digital inside antana to get better stronger and longer ranges to recieve the signal.Go to ur tv Menu.Goto setup Ch. Pick AIR rescan all the free DTV signal again,u should get all channel and a strong signal.
Jul 29, 2010 | JVC LT-32E478 TV
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
How can I hook up 2005 Mitsubishi LT-3780D with cable TV? Because in the back of TV looks more like computer's monitor, I can not connect it with a cable cord.,
Your LT-3780 LCD is only one part of a two-part television system. The LCD is the "monitor" and the HD-4001 "Media Center" is where the inputs and outputs are for the television. The HD-4001 was included with the LT-3780. They are connected together with an HDMI cable and a Serial Cable for communications. If you don't have the HD-4001, you can connect your cable box or DVD player directly to the LT-3780 with an HDMI cable. You will not have any means to connect more than one device at a time, as this feature was performed by the media center. You will also be unable to connect any S-Video, Composite, or Component devices, as these connections are only on the back of the Media Center.
Aug 13, 2009 | Mitsubishi LT-3780 37 in. LCD Television
No Picture
I am deeply sorry but you will need to replace the backlight bulbs. These are not available.
Look on Ebay for a 32" JVC with a broken LCD Screen. Buy it and use these bulbs to fix your TV. I am sure there will be a few good ones in the broken TV. It's that or list it on Ebay for $50 and expect to get about 200-300.
LCD Panel repair for this problem is $500 for parts so you are stick with repair yourself or sell.
May 27, 2009 | JVC LT-32E478 TV
No Picture
Backlight Bulb is out.
You cannot purchase these as a spare part, you must purchase the complete backlight.
Backlight cost is more than or equal to a new TV
You may sell this TV on Ebay (list your exact symptom). Start at 100 you will get about 250. Take this money and buy a new TV.
LCD backlights don't fail often but when they do there are no part available to repair them so you get stuck buying the complete assembly part. This is more expensive than a new TV since LCD prices have dropped so much in recent years.
Apr 19, 2009 | JVC LT-32E478 TV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
