Question about Seagate U6 (ST340810A) 40 GB Hard Drive
How to format IDE hard drive?
How to format IDE hard drive that displays boot disk failure?or make it IDE slave Hard drive...... Seagate U6 (ST340810A) 40 GB Hard Drive.....pease help
  • 532 Answers
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Posted on Jun 18, 2010
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
I HAVE MY MASTER 160Gb SATA SEAGATE, I HAVE TO ATTACH A NEW 500Gb SATA SEAGATE ,I'VE GONE TO BIOS SET UP. BUT IT DOESN'T DETECT MY NEW DRIVE.CAN YOU SHOW ME THE WAY TO SLAVE A SATA SEAGATE HARD...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
May 16, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Not detecting hard disk. when i plug my IDE hard drive the red and yellow LED in my computer always light
Be sure about Master-slave pin jumper. If it is sharing same cable from main HDD please set it as slave, but if alone, then set is as master or Cable Select.
Dont forget to rate!
Jun 17, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to install operating system?
If you have pata hdd try set it's jumper to second no.
May 31, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Add slave hard drive
I am assuming IDE not SATA ? did you set the jumpers on the drives themselves? the seagate 80 to master the 20 to slave. The jumpers are on the front of the drives next to the connectors. Next connect to the motherboad behind the master drive or seperately on a 2nd IDE connector. If you are connecting both with one cable make sure the master is added to connector at the end of the cable.
Mar 08, 2008 | Computers & Internet
Seagate U6 (ST340810A) 40 GB Hard Drive Logo
371 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
