Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
I face a problem to connect a to office with a 95mtr cat5e cable.switch is not blink on both hands.
    President:
  • 623 Answers
95 meters is simply too long. No way of getting a signal on the other end without the use of a repeater. The maximum distance for CAT5e and CAT6 is 295ft, which is roughly 90 meters, but even that only works in an ideal environment. Often the max distance is announced with "300ft = 100m", but that is not true (and 300ft are only 95 meters anyways.)
The best option is fiber optic cable, but that is very expensive.
Read also this article - it has some good explanations and comments.
I would buy a cheap router (WRT54G i.e.) and modify it with some third-party firmware as repeater. That would cost you not more than 25-50$. (Tip: google "Router as Repeater", and you will find many results.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jun 01, 2010
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Oct 31, 2013 | HDTV Supply 12x8 stackable digital/analog...
Lag switch
Hey, you are dealing with high frequency - what a strange idea is this? Do you have a 100Mb/s- or 1Gb/s-network? What do you want to achieve?
Jul 23, 2013 | Cat5e Computers & Internet
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Need to know what i need to connect my prewired home (with cat5 cable running from box in garage to jacks in 4 rooms) to the internet. currently just have cable modem in office.
You would need a 4 - 8 port router... with a wire going to each Jack... and these would plug into the Router ports, The router plugs into the Modem. You have to put the Ethernet plugs on each end of the Cat5 cable. Then you setup your network. But if you have a wireless router you simply need each PC WiFi enabled, IE: A wireless card in each PC, that way you do NOT need Cat5. Then each PC, simply connects to the Router/Modem.
Mar 05, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Hi, I recently bought a XTENDEX® ST-C5USBV-300 USB KVM (Cat 5/5a/6) extender KWM switch. When I connect it to a HP DC 5800 SFF desktop I can´t get any video signal when it´s connected via a...
Well see Cat5 & Cat6 are different spec's and are wired differently...They have different wires inside the cable. You would be able to use the actual Wires, BUT they will have to be wired to the "Other" standard in the Outlet Jacks. Either that or get one that works on Cat6. http://www.connectworld.net/syscon/support.htm
Mar 04, 2010 | Belkin OmniView CAT5 KVM Extender F1D084
I have a broadband DSL modem/router in my home office. I also have 2 CAT5e ports there. I want to feed the Internet signal from the router (one of the ports on the back) through a CAT5e point up to my...
Hi Joe,
How are you connecting to the port in the back of your router? if you have crimped a male plug on to some UTP cable then this may be the problem. UTP cable has a solid condutor and needs a different male crimp plug than UTP patch cable, which has stranded conductors.
I suggest you connect the UTP cable between the office and the loft to an RJ45 wall or surface socket in the office, use a terminating tool designed for the make and type of outlet you use, i.e. if using an ADC socket use the ADC termination tool. The sockets are designed for solid cable and have a colour code for you to follow. Then use a factory terminated patch cord between this socket and the router port.
I assume you have terminated the cable from the office onto one of the patch panel ports and want to use a patch cord to patch from this incoming socket to the sockets that are terminated onto the cables going to your other rooms. If you have access to a laptop connect this directly into the router port and ensure you have an internet connection, then plug the patch cord connecting the loft port into the router and take the laptop into the loft and ensure you have a connection at the incoming port on the patch panel. If you get the connnection there then use a factory patch cord to patch to a room you would like a connection in and then take the laptop to that outlet and ensure you have a connection.
If you want to run outlets in multiple rooms without re-patching every time then you will need to have an active switch in your loft and connect the port from the office to this and then patch out of the switch ports to the various room outlets.
Hope this helps.
Cheers, Jason
Apr 27, 2009 | 10 10 Computer Patch panel
Is it possible to have 2 pieces routers to expand the distribution of internet connection instead of using router to hub? what type of cabling should i used to do it? please help thanks
I guess you have a single incoming internet connection and wish it to be shared.
You only require one DSL / Cable router. To share this connectivity you will need Ethernet / Cat5 or wireless.
An ethernet switch or hub will enable you to extend connectivity.
All cable should be CAT5e or CAT6.
Suggest you consider the slightly more expensive switches that have auto-uplink. The negates the need of crossover cables.
Regards B.
Mar 21, 2009 | 3Com Computers & Internet
Blinking light on NetGear FS108
One LED is a Link light that will blink on activity.
The other shows link speed.
These boxes have AutoUplink negotiation so no crossover cables are required.
Test again with a standard straight though ethernet / CAT5 cable.
Mar 19, 2009 | NetGear FS108 8-Port Ethernet Switch
How to wire up a cat5e faceplate with cat 5e wire
If you want to learn how to wire cat5e, here is a video:
http://www.serverracksandcable.com/cat5-cat5E-cat6-cat6A-cables-limitations.php
Mar 07, 2008 | Computers & Internet
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
187 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
